Keeping Windshield Clear of Salt
Discussion in 'Questions From New Drivers' started by bertita1986, Feb 23, 2018.
  1. bertita1986
    bertita1986 Light Load Member
    174
    75
    Sep 30, 2017
    Do any of you road junkies know how to deal with the salt build up from blocking your view when traffic passes you?
    I find I'm having to stop at just about every fuel island to clean the windshield off, otherwise I go through 1-2 gallons of Peak per day.
  3. LGarrison
    LGarrison Road Train Member
    1,246
    996
    May 19, 2011
    Sandpoint Idaho
    I used two milk jugs full of water where you can get it out of any tap free with was a clean paper towel I will flush the salt off and wipe it down then use my glass cleaner to polish it up and yes you will have to do this over and over and over until winter is over
    Dan.S and Lepton1 Thank this.
  4. Mattflat362
    Mattflat362 Road Train Member
    2,696
    5,723
    Feb 18, 2015
    Avon Lake, Ohio
    I just go ahead and use and abuse that window fluid man!! A gallon a load is no biggie for the 30 days a year or so that actually we need it....(really only 30 or 40 BAD days a year out here IMO.)
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    I use to stock up on washer fluid before the season started. Usually could get it on sale in the summer or fall. I would buy 7 or 8 cases and would make it to spring with that.
    Use to drive a lot through Ontario and BC, they were the worse for road spray.
    Lepton1 and AModelCat Thank this.
  6. Mattflat362
    2,696
    5,723
    Feb 18, 2015
    Avon Lake, Ohio
    I also keep a spray bottle full of washer fluid and a good rag handy.
    Dan.S and Streetroddreams Thank this.
  7. Ridgeline
    22,368
    116,034
    Don't keep heat on the windshield and don't keep the cab temps high.
    Dan.S Thanks this.
  8. skellr
    skellr Road Train Member
    8,737
    12,185
    Jul 17, 2011
    The Village, Portmeirion
    Good wiper blades help alot. Wiper blades don't last like they used to. I blame synthetic rubber for that.
    Dan.S and LGarrison Thank this.
  9. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Park until the roads dry up.
  10. Moose1958
    Moose1958 Road Train Member
    15,158
    33,346
    Dec 17, 2010
    Williesburg, Virignia
    Well you could always ---------
    Dan.S, Lepton1, tscottme and 1 other person Thank this.
  11. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    turn them wipers on high and leave them on
