Kenworth isx12 oil pressure stuck at 21psi?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mixingconcrete, Aug 19, 2022.
  1. mixingconcrete
    mixingconcrete Light Load Member
    97
    39
    Apr 14, 2019
    Hello have a 2017 kenworth t880 with a isx12 and the engine oil pressure was stuck at 0 and now it is stuck at 21psi even when truck is off and key on.
    Changed the oil pressure sensor and its exactly the same? What else should i be looking for?
    I checked harness for damage but it all looks good
  3. Goodysnap
    Goodysnap Road Train Member
    2,990
    6,989
    Jul 12, 2017
    Any active faults?
    You may have to clear to get the pressure to start reading again after the new sensor.
    Default value most likely.
    spsauerland Thanks this.
  4. mixingconcrete
    97
    39
    Apr 14, 2019
    no fault codes. Thats the weird thing. Im guessing since its stuck at 21, the ecm probably thinks that everything is all good
  • Draft saved Draft deleted
