can someone please tell me how to remove the center console to get to the abs module on a 2007 kenworth t600. i am building a custom hauler to transport multiple rv at once and have the abs light on so it's going to pass a dot inspection right now. i was able to move the axle forward almost 30 inches with no problem but can't for the life of me figure out how to get the console apart to get the abs codes. i am pretty sure it has the bendix controller as everything else brake related is bendix and from what i'm finding i should be able to get the codes by the lights on the unit. i have the cup holder out and can feel the unit but can't see any lights on it. if it makes a difference it has the automated trans so the shifter is in the console
thanks
kenworth t600 abs module access?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jpx2, Jun 15, 2026.
ok so i was able to console off and found the abs controller but it is not the one with lights on it and there is also no button to push for dianostics like a bunch of people online have said. we also tried the hitting the brake 3 times within 15 seconds and never get any flash codes can anyone tell me how to get to the code without finding someone to come out and scan it? the truck is not driveable right now due to it not having a new driveshaft after moving the axle
thanks -
If the module you have supports flash codes there will be a ABS diagnostic button under the dash on the left side next to the diagnostic port or on the kick panel to the left of it.
After key on you wait 2 seconds then press the diagnostic button for a second and release, then it will flash the codes.
Most likely you have a Bendix EC-60 or possibly a EC-80 ABS module. -
the only switch i'm finding is the eng/elec switch the part number on the abs module is
5012226 but it doesn't have any numbers that start with EC -
ok so haven't had much time to work on it between cdl classes and moving the axle 30 in forward, replacing the brake canisters one of the abs valves that leaked and a a leaky parking brake relay.but i still have the abs light on so can anyone tell me how many fuses the abs should have? i checked the harness at the abs module and between the 2 connectors only have power to 1 pin. i do know that i have some corrosion in the bottom of fuse box that is keeping my fog lights from working but haven't torn it apart yet. of course when we bought the truck it was missing the fuse box cover and i haven't been able to find a diagram that matches yet to just see if it should have more then 1 abs fuse. thanks in advance for any help as i'm learning big trucks as i go. biggest lesson learned so far is the bigger the truck the bigger the bills
