Kenworth t600 questions and 3406e
Discussion in 'Kenworth Forum' started by united972, Dec 24, 2020.
  1. united972
    united972 Light Load Member
    97
    9
    May 26, 2016
    Hi,
    guys I’m looking at this truck it’s a 2000 kenworth t600 with a little over a million on the miles.
    how are these engines can these go maybe another 200-300k before a rebuild since it has already one mill on the odometer
    this truck is in auction what would you pay maximum for it?
    things I see is air compressor needs changed and ac compressor as of visual check.
    It’s a 10 speed
    Can’t remember the ratio
    but attached is pics and I drained some oil for oil sample that’s attached as well.
    Trucking Jobs in 30 seconds
  3. zinita17601
    zinita17601 Road Train Member
    1,105
    1,077
    Aug 19, 2010
    lancaster pa
    The 1999 2ws i have got 1.4 million on it,still going strong.
  4. united972
    97
    9
    May 26, 2016
    Nice is it stock? How does it pull uphill loaded?
  5. zinita17601
    1,105
    1,077
    Aug 19, 2010
    lancaster pa
    Stock,im afraid to do anything to it that will mess it up.
    Will drop a two or three gears fully loaded cause tthere is big drop in the rpm every time i shift,a 13 speed will be nice.
  6. Shawn2130
    Shawn2130 Medium Load Member
    677
    1,311
    Sep 20, 2015
    Ontario
    Ours is a 1998 Ford Louisville with a 475 6TS.
    Over a million miles of hard use. Almost 39,000 hours. Three transmissions. A snapped drive shaft which also destroyed a 46,000 front and rear diff.
    Did a lot of highway, now is a lot of short trips, idling, heavy haul.
    This year I put a turbo and 6 injectors in it with a wiring harness. Bumped the tune a bit to 525 hp.
    This engine is still working good.
  7. Rubber duck kw
    4,743
    12,537
    Dec 9, 2017
    It could go another couple hundred thousand or it could be blowing oil out by the gallon on the first load.
    Caterpillar Cowboy and Shawn2130 Thank this.
  8. Onemanshow
    Onemanshow Light Load Member
    101
    61
    Jan 29, 2016
    richmond hill on
    Oil report is from April, that's funny
  • Draft saved Draft deleted
