Kenworth t680 2016 front hvac blower prob.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pierre-Carl, Sep 24, 2020.
  1. Pierre-Carl
    Pierre-Carl Bobtail Member
    hi guys here i have a 2016 kenworth t680 with a brushless blower the motor stops and starts on its own, i have checked the climate control by replacing it with one i had in stock, always the same result. what are the symptoms of a worn brushless blower?
  3. Goodysnap
    Goodysnap Road Train Member
    3,502
    8,384
    Jul 12, 2017
    You need to connect ESA and check for faults. Most common is shorted Actuator or broken panel / temp door. When faults come active blower will cut out.
    There were issues shorts with actuators dated prior to 2016. Not so much after, just here and there.
    spsauerland Thanks this.
