Good day fellas,
Today after the delivery i was supposed to go to pick up a load but truck had different plans. Transmission decided to give up on me. Started flashing Tranny needs to be services and won’t shift past 4th gear. When i turn the key in on position i hear some air leak looks like internally it goes hsss stop hsss stops 5-6 times and it stops leaking and i can tell on the dash that is loosing air. Turn the key off and on again same thing until it drops to like less then 100 then it does not leak. Tried pulling the fuse to reset but with no luck service light still here. I can’t even put it in Reverse only drive with the warnint light flashing. I have to put it in drive then back to neutral then back to drive and will put it in drive. Not right. Truck has 400k miles still under warranty but i hate going to dealer but looks like i have no other option but to test my luck and see if they will cover it under warranty. Any opinions on this issue, maybe anybody has been in the same situation ?
Here are the codes
SPN 525 FMI 12 · Transmission Requested Gear — Bad Intelligent Device Or Component
SPN 6146 FMI 1 · Transmission Shift Rail 3 — Data Valid But Below Normal Operational Range - Most Severe Level
Kenworth T680 2022 automatic transmission issue
Discussion in 'Kenworth Forum' started by RoadRanger^^, Sep 18, 2026.
