Kenworth w900l air compresor?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MST123, Feb 27, 2026.
  1. MST123
    MST123 Bobtail Member
    Feb 27, 2026
    Czech Republic (Europa)
    Hello Iam Martin
    I am from Europe and have owned a Kenworth W900L, year of manufacture 2003, Cat 6NZ engine for 5 months. I am putting the car together over the winter so that I can drive it in the summer and make some money. I want to ask the owner of the Kenworth something about the air.
    The car inflates to 120 psi, deflates to dryer air and the pressure slowly starts to drop to 90 psi where it stops. After stepping on the brake it starts to inflate again to 120 psi and this repeats. It inflates to 120 psi and in about 30 seconds the pressure drops to 90 psi, no leaks anywhere. Is this normal? Or is there a problem with the Bendix D2?
    Thanks for the apology for the translation, I prefer to write this through a translator.
    Bean Jr. Thanks this.
  3. Big Road Skateboard
    7,179
    40,676
    May 2, 2021
    Yes, it sounds like it's operating normally, but you have a leak somewhere.
    Shut the engine off after the dryer pops off and listen for the leak. Use soapy water too and look for bubbles
    I'd look at suspension and cab leveling valves and air bags first
    Rideandrepair and BoxCarKidd Thank this.
  4. MST123
    Feb 27, 2026
    Ok, thanks for the reply, I'm currently putting in new bags, so I'll try it out once I have them installed.
    It's true that the filling valve on the bags works a bit strangely and quite slowly, it's possible that it might not be sealing.
    Thank you
    Rideandrepair Thanks this.
