KW 2006 W900 Air Brake issues
Discussion in 'Kenworth Forum' started by Cindy, Aug 5, 2025.
  1. Cindy
    Cindy Light Load Member
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    Hi, I have a KW 2006 W900 cat C15. I fixed an air leak. I started the truck up to let the pressure build up. The primary gauge went to 130 quickly, the secondary gradually got up to 130. So I shut the truck off, I pushed the valves in, turned the key on, and I started pumping the brakes to do the low air pressure test. The light came on about 60psi and the buzzer never sounded. The air went all the way down to about 5 pounds before for the brake valves pop out.
    I have another question. Can the parking brake be bad? Thanks
    Does anyone know what the problem would be? I appreciate any help.
    Thank you.
  3. wore out
    wore out Numbered Classic
    17,421
    216,759
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I would start with the tractor protection valve for the valves popping out. The buzzer is gonna be an electrical problem of some sort. Either power to buzzer possible bad sending unit telling buzzer to come etc. without some diag there it’s impossible to say
    Big Road Skateboard Thanks this.
  4. FLHT
    FLHT Road Train Member
    1,437
    2,576
    Aug 2, 2014
    I found that if you don't use both valves all the time one seems to stick .
    A bit of silicone or wd 40 on the valve may loosen it up
  5. Cindy
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    I'll look into that. Thank you for the reply, I appreciate it.
  6. Bean Jr.
    Bean Jr. Road Train Member
    5,574
    9,936
    Mar 30, 2014
    The buzzer is part of the idiot light module. Its simply broken. Replace the whole module, and the buzzer will work. They go off the same sensor.
    wore out Thanks this.
  7. Cindy
    76
    7
    Sep 15, 2011
    Lakeland, Fl
    Thank you.
