KW W900 Airbags
Discussion in 'Kenworth Forum' started by lantern756, Feb 6, 2018.
  1. lantern756
    lantern756 Bobtail Member
    23
    Nov 9, 2017
    According to my mechanic it is time to replace all 8 of my airbags on my W900 (AG200 suspension). Just curious if anyone has an idea of what is to be expected for both the cost of labor and parts?
  3. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    Why, are all eight of them leaking or cracked beyond use?
    If they aren't, there's no need to replace them yet.
    AModelCat Thanks this.
  4. AModelCat
    159,112
    I agree. Unless they're leaking or damaged/deteriorated I wouldn't be too concerned about it.
    You're probably looking at about $100-$150 per bag plus a few hours labour. Wouldn't be suprised to see the bill in the $1,200-$1,400 range.
  5. lantern756
    23
    Nov 9, 2017
    They mechanic says the rubber is starting to crack so it’s just a matter of time before one blows out.
    daf105paccar Thanks this.
  6. lantern756
    23
    Nov 9, 2017
  7. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    If you have the dough to put down replacing them then i would go ahead and do it. Peace of mind anyways.
    lantern756 Thanks this.
  8. lantern756
    23
    Nov 9, 2017
    If one blows out do you loose the whole air system?
  9. Ruthless
    Ruthless Road Train Member
    8,948
    88,124
    Aug 28, 2010
    The City.
    Yeah. All the air would push out. Have to pinch the line going to the one that's busted.
    I ain't everybody....I'd replace all of them without a second thought. They last a long time, n if they're starting to crack up they been on there quite a while.
  10. blairandgretchen
    13,377
    71,914
    Dec 9, 2011
    South west Missouri
    Second that -
    I had one go on the road - pain in the rear.
    The other 7 got replaced quick smart when I got home. $100 or less odd each.
    If one is starting to perish, the others will follow.
    ShooterK2 and IH Truck Guy Thank this.
  11. Caterpillar Cowboy
    Caterpillar Cowboy Heavy Load Member
    837
    607
    Nov 11, 2010
    Wyoming
    Back when I still had trucks with air ride, I always carried fittings with me to cap it off so I can replace it in the field using the trucks air system as a jack. First one I lost I was back up and running in about two hours including chasing down parts. Since then they got replaced when they were starting to look bad.
    ShooterK2 Thanks this.
