KW wheel seal leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Gumper, Jan 23, 2020.
  1. Gumper
    Gumper Road Train Member
    1,475
    3,197
    Jan 7, 2018
    Butte, MT
    Have a leaking wheel seal on my front drive axle. Can someone help me out with a part number? Wheel bearings could also be bad. Eaton DS402, vin VR75212. The local KW dealers are crooks, so I’d rather order through someone else.
  3. Slowpoke KW
    Slowpoke KW Road Train Member
    1,125
    12,653
    Dec 7, 2015
    OK
  4. spsauerland
    spsauerland Road Train Member
    3,853
    9,842
    May 31, 2010
    West Harrison, In
    Wheel seal SKF 47691 hand installable. Timken bearings Set 401(outer) and Set 403 (inner). If aluminum hub, hub must be heated to install cups. A complete loaded preset Conner hub for drive axle including studs is only around $270. I just picked up four of them on sale for $230 a piece.
    SAR, Gumper and pushbroom Thank this.
  5. Gumper
    1,475
    3,197
    Jan 7, 2018
    Butte, MT
    Those two are a bit different in dimensions mainly the width.
  6. spsauerland
    3,853
    9,842
    May 31, 2010
    West Harrison, In
    47692 is wider one. 47691 was designed to give more room for ABS tone ring.
    blairandgretchen and SAR Thank this.
  • Draft saved Draft deleted
