I have a 97 Peterbilt 379 and water is leaking inside my cab from the AC. The drain tube is clear and ac works good. Can anyone point me in the right direction of how I can fix it?
Leaking ac in cab 1997 Peterbilt 379
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dairy Hauler, Jun 25, 2025.
Did you open the box that houses the evap coil? There could be a crack and water likes to take the path of least resistance. There could also be something blocking/partially blocking the drain.
Bean Jr. Thanks this. -
Triple check the drain tube. It sounds like it's still clogged.
They’re a problem.Iamoverit Thanks this.
