LED Headlight Upgrade for 1997 FLD 112
Discussion in 'Trucks [ Eighteen Wheelers ]' started by turboguy, Aug 17, 2026.
  1. turboguy
    turboguy Light Load Member
    138
    27
    May 16, 2015
    hey guys
    I am looking to upgrade the headlights on my 1997 FLD 112 to the JW speaker 8800 model- heated model
    Will I need to run a separate wire to a switch to turn on and off the heater or will this be plug and play?
    Thanks in advance
    singlescrewshaker Thanks this.
  3. turboguy
    138
    27
    May 16, 2015
    it looks like the converter harness is included
    Does anyone have the JW speaker Model 8800 EVO-X?
    how do you like them? Are they worth the money?
  4. FLHT
    FLHT Road Train Member
    1,506
    2,789
    Aug 2, 2014
    Make sure the lights have the DOT stamped into the lights.
    That's a DOT oos violation if they can't find anything else.
    cke and singlescrewshaker Thank this.
  5. singlescrewshaker
    5,092
    45,060
    Dec 31, 2017
    Little Havana, FL
    They are better than the sealed beam halogens..
    I had em in a '93 FLD 120
    Plug and play
    Heater comes on at the pre set temp by itself..
    Went with Truck lite on my 95, low beams only. No heat
    If they iced over I just turned on the halogen highs till I could pull up & scrape em off..
    Isafarmboy, turboguy and cke Thank this.
  6. kwswan
    kwswan Road Train Member
    2,124
    12,113
    Jul 26, 2009
    mcminnville,tn.
    Can't say about the Evo X model but I have the heated ones in 2 different trucks. We like them. We run alot of county and state roads in addition to interstates and they light up the road good. Make sure to aim them properly and you won't have any problems.
    singlescrewshaker, cke and Sons Hero Thank this.
  7. turboguy
    138
    27
    May 16, 2015
    Thank you for the insight, yes they are DOT approved
  8. turboguy
    138
    27
    May 16, 2015
    I ordered a low beam set so this will be fun to get installed and see the difference
  9. Ridgeline
    22,855
    126,584
    No such thing as DOT approved, the DOT does not approve any thing.
