Life-threatening temps force 8 states to declare extreme heat warning
Discussion in 'Other News' started by Chinatown, Jun 16, 2021.
  1. Truckers Report Jobs
    Trucking Jobs in 30 seconds
  2. Chinatown
    Chinatown Road Train Member
    50,334
    87,545
    Aug 28, 2011
    Henderson, NV & Orient
    Death Valley temperatures could come close to 134 degrees Fahrenheit – the highest air temperature recorded on Earth – in the next couple of days.
    bzinger Thanks this.
  3. Chinatown
    50,334
    87,545
    Aug 28, 2011
    We were running errands, shopping, etc. yesterday in Las Vegas & Henderson. Temperature was 110 degrees, but not uncomfortable due to low humidity.
    I didn't perspire much at all; clothes didn't get damp.
  4. MLC Adventures
    MLC Adventures Light Load Member
    232
    462
    May 2, 2021
    Came through Vegas From SLC Monday night. 107 in SLC when I loaded Monday, 100 straight up at 10:15 that night in Vegas,and 112 in Tucson yesterday when I unloaded. Ridiculous
  5. TheLoadOut
    TheLoadOut Heavy Load Member
    928
    3,398
    Nov 6, 2019
  6. buzzarddriver
    2,368
    4,754
    Feb 1, 2011
    Dallas, TX
    Here in Texas, ERCOT, the power grid manager's have issued a high usage advisory asking citizens to reduce usage. They said there were unexpected outages of electrical provider's.
    Now, back in Feb. we went through blackouts because they, ERCOT, said the grid was not designed to withstand the winter conditions we saw. It was designed to work in the HOT summer heat.
    Well, it is only June, and the temps are only in the upper 90's, no where near record highs. If this heat conditions carry on through till Sept. Texas may be in trouble.
    Myself, i think the grid provider's saw the higher MG/H prices they could get when the supply was decreased and are creating shortages to increase their bottom line.
    TheLoadOut Thanks this.
  7. TheLoadOut
    928
    3,398
    Nov 6, 2019
    Pretty pathetic. I'm sorry but if their one job is to produce electricity, and I'm paying them to do so, they better produce.
    God prefers Diesels and bzinger Thank this.
  8. skallagrime
    skallagrime Road Train Member
    1,072
    1,989
    Apr 10, 2012
    Indiana
    Im not sure you didnt perspire, but due to heat + low humidity it was likely immediately evaporating.
    Had a few loads like that in texas nm and az, didnt think i was getting dehydrated cause i wasnt sweating... big mistake, didnt drink enough, unpleasant experiences
  9. nredfor88
    nredfor88 Heavy Load Member
    809
    2,439
    Sep 26, 2019
    USA
    Way back when my ex and I travelled back and forth between Houston and Las Vegas quite a bit, the stark difference in temps was immediately noticeable stepping out side. Houston at 85 or 90 with the humidity was stifling. Las Vegas at 105 or so was pleasant relatively speaking.
    Years latter after having moved to LV and having been acclimated to year round dry temps, flying back to Texas was like stepping into a sauna. Even on days with low humidity I’d sweat profusely.
    I’ll take desert weather any day.
    The Mojave desert is the driest place in North America. And if I recall correctly, LV is the driest part of the Mojave.
    bzinger and Chinatown Thank this.
  • Draft saved Draft deleted
