Light issue on a Trailer - Avoid violation
Discussion in 'Trucking Industry Regulations' started by goblue710, Jan 14, 2022.
  1. goblue710
    goblue710 Bobtail Member
    Jan 14, 2022
    Has anyone looked into tools that could alert me of lighting issues on a trailer? Anyone have an idea on what that would cost?
  3. lester
    lester Road Train Member
    2,115
    5,039
    Jan 2, 2012
    NW, Iowa
    You mean your eyes? They are typically part of a package deal. 2 free along with hands to open the door and feet to walk around
  4. goblue710
    Jan 14, 2022
    Yes obviously! But talking about while on road! If something goes out while going.
  5. Catmando
    Catmando Road Train Member
    2,540
    10,186
    Mar 15, 2021
    Iowa
    This is a joke right ??..... or is this for real ?????????????... Ever seen 1 of these... it's still in the experimental stage but I've heard good things about it
    God prefers Diesels Thanks this.
  6. lester
    2,115
    5,039
    Jan 2, 2012
    NW, Iowa
    I was going to suggest that to but its a lost cause. And I got yelled at a few times back in the day for using it to alert people of issues. They worried the DOT was listening and would find them
  7. Hawkeye72
    Hawkeye72 Light Load Member
    120
    350
    Feb 20, 2015
    Iowa
    Keep looking. Typically if something goes out you should see something. Lights flickering/ marker lights not working. Or someone will let you know on the radio or when passing you.
    Keep a couple of plastic seals. Sometimes the connections to fit together quite right. And lights will flicker or not work righr. You can put a seal inside connection with truck plug. It will make the parts fit better. If that makes sense.
  8. blairandgretchen
    10,295
    47,548
    Dec 9, 2011
    South west Missouri
    I guess that used to be a thing - I remember that when I started. So, you'd use code like "Hey flatbed, you're missing an eyeball".
    God prefers Diesels and lester Thank this.
  9. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,605
    7,746
    Oct 18, 2010
    NW Indiana
    These things are not made to aircraft quality specifications. Hell, if it is a Kentucky trailer you are lucky if all the lights work from the moment you pick it up at the factory.
    What you are describing is some sort of RF controlled circuit, where all devices(tail light, clearance lights etc.) is all on one supply circuit, one 12v positive and negative to each, and each one has a cute little chip inside that is controlled by a lighting ECM on the tractor. The ECM sends a signal via the voltage supply circuit to each device to do what it is supposed to do, blink, go bright, on, off etc. The technology has been around for a while. Also referred to as fly by wire.
    Don't look for that advance anytime soon given the world can't make enough chips for the stuff that Walmart sells, let alone this safety related item.
    Siinman and God prefers Diesels Thank this.
  10. SmallPackage
    3,095
    8,840
    Dec 20, 2019
    Marion Texas
    In automotive world the newer electronic flashers will do what they call “hyper flash” which is a noticeably faster flash when a bulb on that side is out. But since Heavy duty truck flashers are designed to take loads from 10-20 lamps they don’t always feel the loss of current thru a burnt bulb so the speed may not change. That being said I have seen the speed and rhythm change on a few of them. It is noticeable but only slightly.
  • Draft saved Draft deleted
