Local driver within 100 air miles do you need to take a break.
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Frow4, Mar 28, 2018.
  1. Frow4
    Frow4 Bobtail Member
    I work for a local trucking, the company is switching to eld. I think the reason why is because we do work more then 12 hours a day. My question is do have to take a 30 mins break if you are in 100 air miles of you base.
  3. dibstr
    dibstr Road Train Member
    1,308
    932
    Sep 10, 2010
    If you qualify for the short haul exemption you are not subject to the 30 min rest period. If you are normally not released within 12 hrs you do not qualify for the short haul exemption and are subject to the 30 minute rest period.
    brian991219 Thanks this.
  4. LoneCowboy
    LoneCowboy Road Train Member
    1,466
    3,600
    Oct 6, 2009
    Colorado
    if you start and return to the same place each day and stay within 100 air miles (115 map miles) you can work under the short haul exemption and work 12 hours without taking a 30 minute break. If you are find you are going ot exceed the 12 hour limit you must take your break as soon as possible (even if past the 8 hours).
    Break it up
    There has been some confusion among truck drivers about 30-minute rest breaks when they cease to use the short haul trucking exemption mid-run.
    To clarify:
    • If you break any short haul exemption rules before the 8th hour of on duty, then you need to take your 30-minute rest break before you drive into your 8th hour.
    • If you break a short haul exemption after the 8th hour, then you need to take the 30-minute rest break prior to your 14th hour on-duty and notate your log with an explanation of why you didn’t take that break earlier.
  5. MACK E-6
    48,744
    225,130
    By law, no, unless as another poster noted you find that you’ll wind up breaking the exemption due to time or distance.
    On the other hand, your company’s particular ELD may be set up in such a way where you’ll have to take it anyway. Ours are, but at least we still get paid for it.
