Locking fuel caps and key removal during fueling?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ozdriver, Jul 30, 2021.
  1. Ozdriver
    Ozdriver Heavy Load Member
    767
    1,390
    Oct 16, 2015
    Australia
    Just bought 4 x locking fuel caps for my KW. Genuine Kenworth items, the round screw-on ones. Only problem is, I just found out you can’t take the key out until they are locked. You can’t take the key out when they are unlocked. A real hassle when you’re filling 4 tanks. I only want to lock them occasionally if I’m in a dodgy area. I rang a locksmith and he said they are designed that way, and the only way to fix it is to mill or grind a groove in the fuel cap body. Anyone done this?
    Cat sdp and BoxCarKidd Thank this.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,188
    6,004
    Aug 26, 2014
    No. Sounds correct to me.
    Good to hear from you. It has been long time.
  4. Cat sdp
    Cat sdp . .
    19,879
    64,222
    Apr 8, 2012
    Orion's Belt
    Yes welcome back….
    love your truck…… wish I had 4 tanks….
  5. GEERAVIS
    GEERAVIS Bobtail Member
    16
    Jun 13, 2020
    Do they make locking caps or collars for DEF tanks for 2016 KW T680's? I've been looking,
    but nothing so far.
  6. RockinChair
    RockinChair Road Train Member
    4,196
    9,374
    Feb 19, 2012
    CC, TX
    I have never messed with locking fuel caps, but if you find whatever little piece of metal holds the key in place inside the lock cylinder while the fuel cap is unlocked, just grind it off flush.
    Cool looking truck, BTW.
  7. Goodysnap
    Goodysnap Road Train Member
    3,502
    8,384
    Jul 12, 2017
    Nope never seen one.
    Probably not an issue with theft like there is with fuel.
    If anything It would be helpful to keep away someone from sabotage. DEF contamination is very expensive to fix.
    Is this why you are looking?
  8. GEERAVIS
    16
    Jun 13, 2020
    Yes. I have seen coupling locks that fit over top of fuel caps, and was
    thinking that something like that may work. Perhaps I can get someone
    to fabricate a coupling lock for it as well.
  9. Goodysnap
    3,502
    8,384
    Jul 12, 2017
    The Paccar DEF fill cap is nothing like I have ever seen in the industry, automotive or otherwise. If you come up with a good solution please share your ideas. I will update here if I see anything.
    spsauerland Thanks this.
  10. not4hire
    not4hire Road Train Member
    7,142
    26,950
    May 16, 2012
    Calgary
    I've found locking caps to more trouble than they're worth, but if you insist... I would just have four keys made and keep them on a doohickey like this (or reasonable facsimile).
    MM71 and Goodysnap Thank this.
  11. Goodysnap
    3,502
    8,384
    Jul 12, 2017
    Like every other lock and security device on the planet. If the theives want it bad enough, they will get it. They are indeed a huge inconvenience and very problematic.
    not4hire Thanks this.
