Looking at buying a refer trailer
Discussion in 'Ask An Owner Operator' started by Blu_Ogre, Nov 30, 2014.
  1. Blu_Ogre
    Blu_Ogre Road Train Member
    8,229
    48,587
    Jul 14, 2013
    Out west
    Changing who I'm leased to and looking at buying a trailer. Doing the 53' box, prefer TK refer but need opinions on a couple of things.
    Is there any advantages to spread axles on a box? Spreads allow you to run less well balanced loads. And perhaps slightly heavier loads. But I want to try for lighter weight loads which negates those. Are there any Aero dynamic or economic advantages to Spread over Standard Tandems?
    Any Input on Trailer Manufacturers? Kinda a Ford verses GM kinda question. Know any to Avoid or "Snag if you can get it" manufacturers?
    double yellow Thanks this.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Take your pick as far as thermo king or carrier. I choose TK because of more service locations. Both units are very good. I have heard the carrier is a couple hundred pounds lighter and a bit better on fuel.
    As far as trailer make, I would only buy Utility or Great dane. You need them to hold up well. I have a Vanguard and it is only about 5 years old now, it is already showing signs of wear, the quality is not the same as a Utility or GD.
    Spread axles are nice, but typically are better for heavy loads and 48 footers. Isn't there some wheelbase laws where a spread on a 53 can get you into trouble? Something to research. Spreads are good if you know you will run out of gross weight before you cube out the trailer. Many shippers require 53', even in the reefer business. Strawberries for example they will load you with 30 pallets and will weigh about 30,000. Light loads are not the norm, however. A spread will be less aerodynamic than a closed tandem, but the difference in MPG is negligible.
    If you only are a small company, you want to make yourself available to as many possible customers as possible. That being said, 53' is a must. The spread doesn't increase your gross allowable weight. Just make sure you ask the shipper how many pallets and roughly how heavy each pallet is, from that you should be able to tell them how to load it.
    Blu_Ogre and double yellow Thank this.
  4. Blu_Ogre
    8,229
    48,587
    Jul 14, 2013
    Out west
    Thanks for all the info.
    Old school trick is to put a smooth face cargo box between the spreads. Flush to outside edge of tires.
    Agree the 53' is a must. Single truck operation. Run primarily produce now. Looking for a break/Change so changing who I'm leased to.
  5. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    utility best reefer TK unit ,,sliding tandem,,spread only an advantage in states where you can haul over 80K gross,, get a bulk head in the front of the box, helps air flow, no side door,,and get vents,,
  6. Blu_Ogre
    8,229
    48,587
    Jul 14, 2013
    Out west
    Vents? The small door cut into the swinging door? Or are there others to look for?
  7. Tall Mike
    Tall Mike Road Train Member
    7,368
    34,743
    Aug 20, 2014
    New York State
    Yes...
    If I were to ever buy another based on my experience..
    53' Utility
    TK unit
    Extra insulation for frozen loads (specifically ice cream)
    *might* consider super singles for weight savings I'm still not convinced they are the way to go on the winter roads around here
    two vent doors on top in front (one in each corner)
    two vent doors on the rear doors (one each side)
    I'd spec a bigger fuel tank also so as to buy as much as fuel possible where its cheap (weight ain't a factor I don't cross many scales)
    LED light package to up the cool factor
    Air release slider (I've gotten lazy in my old age)
    What works for me may not be the best thing for you.... :cool:
    Shoot member 'olhand a PM he has a world of experience with reefers and could prolly be a HUGE help..
    Blu_Ogre Thanks this.
  8. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Buy a cheaper reefer. Any trailer will be destroyed by Super Mario riding forklift lumpers in just few months. So go cheaper you can buy more trailers.
  9. Blu_Ogre
    8,229
    48,587
    Jul 14, 2013
    Out west
    Thanks Mike,
    Going Used may make the extra Insulation a challenge.
    Super singles I'm on the fence for. Will Burn that bridge when I need to get tires.
    all else I agree with. Now to exercise my Google-foo
    LED lights I have a buddy to cover. He's special ordered some strings and controllers for me and just waiting for the trailer and rig to be parked long enough......
    Tall Mike Thanks this.
  10. Blu_Ogre
    8,229
    48,587
    Jul 14, 2013
    Out west
    I find that a scowl and bark from the 200 lb 6'+ old hippie gets that crap in check in a hurry.
    But yes the Aluminum wrapped up the wall a foot or so is on the "got to have" list.
  11. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Super Singles will leave you on side of the road. I'm a Great Dane or UT type if I was to get a reefer which I'm not. I pulled them with Aluminum and then 4 ft plywood abv that. Loved it as it can be replaced.
