My truck started pushing coolant out top of resevoir cap but isnt running hot. I see bubbles when its running coming up from bottom
Detroit 13l
Losing coolant, not running hot
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by cuzzin it, Jun 16, 2024.
Check for coolant in the intake by removing the crossover pipe that goes between the intake and the EGR cooler.
It can also be an internal failure in the air compressor, but I think that's not too common.Jordonh, Rideandrepair, ducnut and 1 other person Thank this. -
Now that ive looked at it good, ie: not side of highway. It seems that leak maybe top of radiator under resevior. The other truck (which was assembled right before it according to vin) did same thing. A couple thousand miles out of warranty. I get diagnosis in a few..
Rideandrepair and ducnut Thank this. -
Rideandrepair and cuzzin it Thank this.
Radiator at top of fins, bottom of top. So new radiator. Company bought 3 freightliners 5 years ago and radiators blew nearly same spot in all 3
Air compressor or head gasket pressurizing the coolant. Have a combustion gas in coolant test done and isolate the cooling system from the air compressor and retest.
