Loss of ignition power
Discussion in 'International Forum' started by joejffrs, Oct 17, 2020.
  1. joejffrs
    joejffrs Light Load Member
    52
    14
    Jul 24, 2018
    San Diego
    Have a 2013 Transtar MF 11 that loses all ignition switch power while driving-like the ignition switch was turned off. Still have flashers and cab light. Stays dead for about 15 mins, something resets, and I can start the truck and drive for a few miles and it happens again.
    UPDATE-drove truck loaded and mostly uphill for 15 miles today and it shut down 4 times. Reset after 17-24 minutes each time and started back up. Each time coolant temperature was above 210. Coming home, unloaded and mostly downhill-temp was at 180 and made it all the way home with no shut down.
    Trucking Jobs in 30 seconds
  3. Heavyd
    Heavyd Road Train Member
    7,067
    5,149
    Feb 4, 2009
    Ok, need more info to see how much of the truck is losing power and whether it is main battery or ignition. When this happens, does the cluster go dead too? Do you have an automatic trans? Does the shifter display go blank?
  4. joejffrs
    52
    14
    Jul 24, 2018
    San Diego
    Instrument cluster goes dead-gauges frozen in place until reset. 10 speed manual. No headlights, just emerg flashers and dome light work. Good voltage, engine cranks and fires right up after reset
  5. Heavyd
    7,067
    5,149
    Feb 4, 2009
    I would start with all main battery connections at the firewall including ground connections too. Main battery feeds for the cab also run through the firewall. I believe there are two of them with big connectors right near the firewall. Check for burnt connections or corrosion.
    joejffrs Thanks this.
  6. joejffrs
    52
    14
    Jul 24, 2018
    San Diego
    That was it Heavyd. Removed all battery connections and 100a fuses to the cab at the firewall, cleaned and reconnected them but then had no power to the cab. Found that one of the fuses was bad after jostling it around and cleaning it. New fuses on the way. Thanks Heavyd.
    Heavyd Thanks this.
  7. Heavyd
    7,067
    5,149
    Feb 4, 2009
  • Draft saved Draft deleted
