Loss of power
Discussion in 'Ask An Owner Operator' started by Adriantx, Mar 21, 2021.
  1. Adriantx
    Adriantx Light Load Member
    58
    15
    Dec 29, 2018
    I recently got the clutch replaced and input shaft but now my truck dose not pull how it used to when I'm trying to do my tug test after hooking up to trailer as if it dosent have any power any idea what could cause this truck pulled fine before geting this done.
  3. Magoo1968
    Magoo1968 Medium Load Member
    398
    953
    Mar 18, 2021
    St Malo mb
    Clutch slipping ?? If it’s not adjusted right I can see that happening.
    Vampire Thanks this.
  4. Adriantx
    58
    15
    Dec 29, 2018
    Would I get a code because I am not geting anything on the dash service was done by MHC KENWORTH I don't see them not adjusting clutch to spec?
  5. GFTLLC
    GFTLLC Bobtail Member
    44
    58
    Jan 4, 2020
    Pennsylvania
    I can't see anyway it would throw a code for a slipping clutch. Does the pedal have the right amount of free play? That's a pretty good indicator of adjustment. Would it be possible that the pedal feels ok and the linkage is adjusted incorrectly?
    Vampire, slow.rider and Magoo1968 Thank this.
  6. Adriantx
    58
    15
    Dec 29, 2018
    Pedal feels like it's a little harder but not much truck takes a little longer then usual to speed up
  7. 77fib77
    77fib77 Road Train Member
    5,583
    22,521
    Jul 7, 2010
    St Louis
    The usual are air filter, fuel filters, bad fuel. The later two can happen quickly, air filter takes time.
    Did you have a special program for it? Did they update the software?
  8. GFTLLC
    44
    58
    Jan 4, 2020
    Pennsylvania
    I'm wondering if you didn't have an Eaton easy pedal, I believe they are called, with the old clutch and the new one isnt. That could explain the pedal. The pulling issue is definitely strange and my guess is related to the pedal issue, not the switch in the clutches. Maybe someone didn't set the clutch fork when installing the transmission and tried to draw it up with the bell housing bolts? I would imagine if the release fork isn't true that it would cause a bind on the throw out bearing, which in theory, would cause the pedal to be tighter than normal and possibly not engage the clutch completely. I'm just throwing ideas at this point from when we did my transmission. Keep us posted. My curiosity got ahold of me now.
  • Draft saved Draft deleted
