lost side box keys
Discussion in 'Kenworth Forum' started by rollin coal, Sep 19, 2015.
How about local locksmith?
If you do order from KW post how much they cost please
I don't need a locksmith unless they can make keys? Really I would be impressed if a locksmith could open the passenger side anyways. That lock #### near feels like it's borderline gonna break the key off sometimes have to be careful.
Find some one with close to the same year kw,most of the time it just takes a little wiggle & jiggle to get one open. For the one that's hard to turn,probably just needs to be cleaned and lubed.
rollin coal Thanks this. -
You should be able to order them from KW, may want to just get new locks for your side box (they should come with keys) and replace the sticky one on the passenger side while you are at it, may be about the same cost as getting just the keys.
And then take them to a locksmith to have them recoded to match your ignition key if its the same type of key .brian991219 Thanks this.
Nope. Different key from ignition this is 2003 T600. No chips or codes just a small key.
Locksmiths are resourceful. A good one can open it, and either make a key for you or replace the cylinder with a new one with new keys.
rollin coal and brian991219 Thank this. -
Maybe find out if newer locks like on the t680 fit they use same key as ignition .. It's nice having a big key I hated that small one in winter I was always scared I'd break it when locks iced up
