im new so please bare with me, i have 2002 kw W900L with a C-15 the truck low air light will not shut off. the air pressure is reading 120 and after doing a few internet searches i bought a warning sensor that screws in to the air junction box in the dash. this help a bit it will turn off now 90% of the time but only when it hits 120psi and some time i have to tap the brakes when it hits 120 and it will shut off. the light will come on around 110ish and not go off until the pressure hits 120 again. so i am a bit lost now, I cant find any thing else that points me in the right direction other then a stealership. any idea would be a big help thanks
low air light and buzzard wont turn off even at 120psi
Discussion in 'Kenworth Forum' started by maxpowerss67, May 7, 2012.
yeah i did that recently, helped with my sanity, i read some where the air dyer may need to be replace, idk still searching away i will let you know if i find any thing, did you replace the sensor?, its like 30 buck at kenworth or 15 on ebay really easy to replace.
KW have the TRP air dryer filter on sale ...$19.79 with the KW Privilege card.
I haven't found a filter cheaper anywhere else... -
If you have a water leak and it leaks down onto the sensor, this can trigger it. My Pete did the same thing, put silicone on top of the sensor, haven't had a problem and also fixed the water leak.
