Low Oil Pressure???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Phoenix Heavy Haul, Jul 25, 2022.
  1. Phoenix Heavy Haul
    Phoenix Heavy Haul Medium Load Member
    463
    1,375
    Feb 8, 2022
    Raleigh NC
    Today I was trucking along and my #### CEL came on and lil red light in the oil gauge.
    Pressure was under 40 and wouldn’t rise normally stays around 50.
    Pull over shut it down, I was about half a gallon low.
    Noticed I had smoke coming from the filler tube (which I’ve never had) I assumed engine oil temp had gotten hot.
    Nevertheless when I start it it takes about 5-10 secs before gauge registers pressure. At idle it maintains roughly 15psi when I take off it does fine goes up past 50 like normal as I shift and then rest around 45. The weird thing is the longer I drive the more it drops closer to 40 and dipped right under 40 on my 20 mile drive to the loves.
    I haven’t noticed any drop in power etc.
    And I’ve read that apparently Detriot has seals that go out in the oil tubes in the pan which creates a loss in pressure.
    It’s a DD16 with 450k on it. Any ideas or advice?
  3. Brandt
    Brandt Road Train Member
    4,067
    5,346
    Sep 17, 2012
    Could be the oil pickup tube seals. This guy seem to have quick video first thing he say the seal on pickup tube go bad at about 500k on DD15
  4. Phoenix Heavy Haul
    463
    1,375
    Feb 8, 2022
    Raleigh NC
    Yeah I think that maybe the culprit. Thanks for the video!
  5. slow pok
    slow pok Light Load Member
    138
    207
    Oct 27, 2013
    lizela ga
    Mains are fixing to go out
  6. Chieftains
    Chieftains Medium Load Member
    362
    894
    Jul 18, 2021
    Let us know what it was if you fix it.
  7. Phoenix Heavy Haul
    463
    1,375
    Feb 8, 2022
    Raleigh NC
    Yep I believe she is ####ed!
    Had to add a gallon of coolant this morning,
    Oil on dipstick is now overfull (no milky)
    And oil pressure is idling at 45-50psi.
    Gonna try to get
    This get this load off and get it to shop.
  8. 062
    062 Road Train Member
    5,851
    31,703
    Oct 20, 2013
    Could be fuel dilution. If you can’t smell it, then take a sheet of white paper and put a few drops on it. Fuel will make sort of a halo around the oil.
  9. Phoenix Heavy Haul
    463
    1,375
    Feb 8, 2022
    Raleigh NC
    Thanks I tried that and looks normal. Not sure how fast speedco can do an oil analysis but may try to stop and get oil changed and analyzed
  10. Phoenix Heavy Haul
    463
    1,375
    Feb 8, 2022
    Raleigh NC
    DBA31442-62ED-4A81-92BC-3F66AA424A42.jpeg View attachment 421227
    So I just grabbed my clipboard from earlier where I applied the oil drops. And it appears to be a Halo…rekon it needed time to dry…..check out pic.
  11. LoneRanger
    LoneRanger Road Train Member
    3,549
    9,022
    Jun 3, 2018
    @Phoenix Heavy Haul
    What year is your dd16?
    also if it’s consuming oil, the pickup tube orings won’t be the cause. But it’s still a good idea to change it when opening it up.
    do you have my type of gauges ? If yes you can upgrade the cluster to include the turbo and engine oil temp as well. Its an easy bolt on.
