How are you paying Lumpers? Cash, check, credit card?
Discussion in 'Refrigerated Trucking Forum' started by ReeferOhio, Oct 27, 2021.
  1. ReeferOhio
    ReeferOhio Medium Load Member
    596
    557
    Nov 29, 2010
    Hey all,
    We're typically a flatbed outfit but starting to haul some reefer loads. I know my forum name says different but hey, you never know what you end up doing.
    Anyway I'm trying to figure out what I need to do to prepare for lumpers. Cash, credit? I have know idea how a com check works. What do I need to do to be prepared to pay? Or what service should do I need to set up? Thank you all in advance for any input.
  3. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,389
    Mar 13, 2015
    LOWER 48
    At my company we use EFS.
    I text dispatch with amount and they give me a authorization code.
    Capstone does it over the phone .
    A few places still use a check.
    One place the guy went to the bank and cashed it before he would give me a reciept.
    ReeferOhio Thanks this.
  4. tallguy66
    tallguy66 Medium Load Member
    534
    873
    Oct 18, 2018
    Efs checks and comm checks. A lot of places have gone digital though, where all I need to do is ask my company for a money code which they register the amount I send them to. If you end up using efs get that app, it’s a lot quicker that way to authorize / put money on a check
  5. God prefers Diesels
    4,198
    22,246
    Jun 26, 2020
    South Texas
    @d o g could probably change your username if you wanted.
    d o g Thanks this.
  6. rollin coal
    rollin coal Road Train Member
    12,529
    23,860
    Mar 29, 2008
    TN
    If you're using a company issued fuel card there should be a way to use that to load up an EFS, comdata check or whatever with funds. That's a big, IF your company loads funds on there so you can do that. Talk to somebody in your company office to find out if they put funds on your card for that and how to do it. Really easy. Your company may or may not charge you a small fee to load these checks. There's probably an 800 number on your fuel card that you call and just follow the prompts. You can get free blank EFS or comdata checks from any truckstop or as somebody said the lumper service may not even need a paper check and do it all electronically.
    Alternatively many lumpers will accept payment from your personal credit card. A few still accept cash but most don't and are moving away from accepting it. I use my credit card most times to avoid the $1 fee it costs me to load an EFS check using the company issued fuel card. Plus it's a helluva a lot faster using a credit card than it is going thru a dozen phone prompts to load an EFS or comdata check.
    You may already know how the game goes but just in case you don't. Lumper fees are always reimbursed to the driver as long as you do your job right. If you're running brokered freight always let the broker know there is a lumper fee, how much, and quickly email them a copy of that receipt. As a rule I ALWAYS make them send over an updated rate con with additional lumper money added onto it after I've emailed them a copy of the lumper receipt.
    You can ask for and use the broker's money to cover lumpers but most most of them charge you a fee for the favor. You're better off paying yourself and getting reimbursed.
    If you ever have the displeasure of hauling a brokered reefer load for JB Hunt (they are different than everyone else and really stupid) read the rate con and follow their procedure to a T or the lumper is on you...
    RedForeman, Speed_Drums and ReeferOhio Thank this.
  7. ReeferOhio
    596
    557
    Nov 29, 2010
    yea I am the company so I'm just trying to figure out what's the best route. I Called com data but that was weird monthly subscription, didn't seem correct what she was telling me. She also was supposed to email information for me but that never came.
    As far as fuel card I am through NASTC, I believe that card is issued through fleetone, so just give fleetone a call for EFS?
    I already have a couple direct companies for freight they are large so getting freight as the small guy (few trucks) can be a challenge sometimes, so I'm sure I'll broker sometimes. Thank you for the responses.
  8. 062
    062 Road Train Member
    5,852
    31,733
    Oct 20, 2013
    Capstone is using the Relay app. I think there is a way to set up your company so that lumpers will be automatically deducted.
    With a NASTC fuel card you should be able to get money codes on the fleetone website.
  9. ReeferOhio
    596
    557
    Nov 29, 2010
    Yes, I am setting up through fleetone now. I will get the capstone app as well, and see what is required for set up. Thank you.
  10. rollin coal
    12,529
    23,860
    Mar 29, 2008
    TN
    Not sure is NASTC is EFS or not. It's been several years since I had it for a fuel card and I never dealt with lumpers back then either.
  11. bad-luck
    bad-luck Road Train Member
    3,023
    5,437
    Nov 16, 2013
    Baltimore, Maryland
    Generally the shippers pay for the lumpers. You call the broker with the amount and they issue you a code for a com check, EFS Check, or T check. However, the broker fees for checks have gotten out of hand. I have see as much as a $20 fee. I am set up with EFS, and I can generate a code myself and the fee is $3.00. I have heard that some guys use a card and there is no fee, I don't have a card so I can't answer that. Maybe someone else here can answer that for you.
