Mack coolant contamination?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BoxCarKidd, Feb 13, 2018.
  1. BoxCarKidd
    BoxCarKidd Road Train Member
    2,053
    1,736
    Aug 26, 2014
    Does any one know what causes this? It is a 05 Mack which has the two cap plastic tank. The lower cap has what looks like oil snot on it. Bad oil cooler? But the top cap has what looks like smut or exhaust. However when smeared on card board it feels like grease. Coolant looks clear.
    Truck surges and smokes on take off. IMG_20180213_155506385_LL.jpg IMG_20180213_155532098.jpg IMG_20180213_160427001 (1).jpg
  2. spsauerland
    spsauerland Road Train Member
    1,597
    3,766
    May 31, 2010
    West Harrison, In
    Sure looks like soot. Is this an AI or AC engine? Possible EGR cooler on AC engine. I have had more trouble with transmission coolers leaking than engine oil coolers leaking.
    BoxCarKidd Thanks this.
  3. BoxCarKidd
    2,053
    1,736
    Aug 26, 2014
    AC. Wondered if EGR could be leaking and mixing soot with oil in the cooling system. That just seems like an awfully odd dog to me. I will have to check out the trans cooler however fluid is good.
  4. Brettj3876
    Brettj3876 Road Train Member
    2,437
    5,120
    Nov 18, 2014
    Northeast PA
    Check out big mack trucks forum they might be able to help out more. I think over there you can talk about how to "fix" your egr
  5. BoxCarKidd
    2,053
    1,736
    Aug 26, 2014
    Driver using and used oil jugs to add water surely helped out. Probably has an egr cooler problem also.
  6. spsauerland
    1,597
    3,766
    May 31, 2010
    West Harrison, In
    I was wondering about cross contamination. Had a driver put fuel additive in coolant that looked like that.
  • Draft saved Draft deleted
