Manual vs Autoshift and Surge
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Flatbedder73, Aug 5, 2013.
  1. Flatbedder73
    Flatbedder73 Medium Load Member
    464
    354
    Dec 30, 2012
    Langhorne, PA
    Ive always driven a 10 spd manual....the owner I drive for may be putting me in a Prostar with an automatic. Is it possible to have as much surge control in the auto as I do with the manual? I love my Columbia, and will miss the Fuller.
  3. Chinatown
    Chinatown Road Train Member
    74,672
    169,770
    Aug 28, 2011
    Henderson, NV & Orient
    I haven't driven the Prostar, but did drive a Freightliner and Volvo with automatics. Hated the Freightliner because the transmission seemed to get confused as to what gear to be in during surges. The Volvo had a Volvo engine married to a Volvo automatic transmission & it was the most relaxed,comfortable driving I have ever done. Drove the Volvo 48 states & Canada with no problems at all with surges, in all terrain & weather.
    Flatbedder73 Thanks this.
  4. Flatbedder73
    464
    354
    Dec 30, 2012
    Langhorne, PA
    cool....I hope the Prostar is like that!
  5. Big Duker
    Big Duker "Don Cheto"
    2,921
    2,867
    Sep 18, 2007
    Weatherford, TX
    More than likely it won't be. Will have Eaton. If old and is Autoshift w/clutch may be ok. I am going back and forth now with 2012'Volvo and 2011' Cascadia. Volvo 12 spd is far superior to 10 Ultrashift in Shaker. Neither one has much to do with surge. That's on you and your driving habits. Ultrashift is OK but can be annoying in reverse. Both will get the job done. Our 2013 Volvos are much more refined. Skip shift when empty or bobtailing. May take off in 2nd=jump to5th-8th-11 in a few hundred feet. Have Blue Tooth on wheel. Take some getting used to after 15 months in a 379EH. But really good for maneuvering around DFW.
  6. Calspring
    Calspring Light Load Member
    290
    144
    Jun 22, 2012
    Canada
    I can't give you any personal experience but I can tell you that around here of the three major fuel haulers, one has replaced their whole fleet with Pinnacles with M-drive (Mack Programming on an I-shift) and another has recently received a few units likely to test out. The third is running Western Stars. Not sure of the transmission in them though.
  7. Threedog
    Threedog Bobtail Member
    42
    14
    Jul 1, 2013
    Dartmouth, Nova Scotia
    I am running a Mack M-Drive. I got them to put the easy shift option into the transmission computer and with that there is next to no surge at all between gears. I am very satisfied with that set up after thinking it wouldn't be any good.
  8. crazystalin
    crazystalin Light Load Member
    150
    40
    Feb 5, 2013
    NC
    Hope that international prostar not have a maxforce engine. If does just push it off cliff. I drove volvo with 10 speed ato shift am d like op said smooth ride and shifting. Only this that is problem is backing an auto. Not like car when put in reverse and you start moving. Had to press gas pendel and break to control speed. I used hand break but a lot times seemed to hit dock hard.
    Flatbedder73 and whoopNride Thank this.
  9. mustang190
    mustang190 Road Train Member
    2,844
    6,111
    Jan 18, 2011
    Florida Panhandle
    The company I work for is dropping all auto shifts. Nothing but problems. Sure they work great while new, but get a couple hundred K on them and watch what happens. The surge kills them.
    A manuel shift is a lot easier to run.
  10. Flatbedder73
    464
    354
    Dec 30, 2012
    Langhorne, PA
    Well great news....I get to keep the 05 Columbia!!! They put someone else in the new truck, and I couldn't be happier. I'll take a Freightshaker with the EF 10 spd any day.
  11. thirdreef
    thirdreef Medium Load Member
    602
    185
    Jul 8, 2013
    Reno,Nv
    I've driven trucks with Alison transmissions . They have been making truck transmissions for over 40 years. And never had any problems with any surge, or anything.. But they do need some maintenance , like anything else. But they are expensive.
