Mattress questions for 2027 Cascadia
Discussion in 'Experienced Truckers' Advice' started by Geezweez, Sep 10, 2026.
  1. Geezweez
    Geezweez Bobtail Member
    4
    Jul 8, 2024
    I started to learn about beds a year ago. Before I had been sleeping on whatever was in the truck, but since I'm going back to living on the highway I thought I'd get the best I could. Have a few questions about the interior fitting:
    The bottom bunk is 42" wide for the basic configuration correct? Has anyone here put a twin xl on the 42" bunk? 4" of extra unfilled space seems like a lot.
    I'll be in the raised roof with the folding top bunk which will be folded up. How tall of a mattress can I really put in there? Looking at a 14" model.
    How much storage space would I lose by having trouble lifting the bed tray? Also I don't care about being able to use the little pull out shelf. I care most about sleeping as good as possible.
    Thanks in advance!
  3. Zeus 49
    Zeus 49 Light Load Member
    156
    75
    Sep 3, 2026
    All depends on your requirements for sleep . Myself personally I can sleep on a bale of hay . It depends on your willingness and return on investment. If helps you perform get what you think is best and reassess as needed .
  4. gentleroger
    gentleroger Road Train Member
    8,222
    22,618
    Jun 1, 2010
    The only problem you'll run into with a twin xl is getting it in the cab. One person can do it alone, its easier with 2, 3 is ideal.
    Lonesome Thanks this.
  5. Moosetek13
    Moosetek13 Road Train Member
    15,190
    19,445
    Nov 1, 2010
    Burnsville, MN
    I'll add, make sure the passenger seat is fully lowered.
    gentleroger Thanks this.
  6. gentleroger
    8,222
    22,618
    Jun 1, 2010
    Drivers side too
    Moosetek13 Thanks this.
