MAXIMUM AXEPTABLE LATERAL INCLINE
Discussion in 'Ask An Owner Operator' started by albatros1952, Aug 14, 2026.
  1. albatros1952
    albatros1952 Bobtail Member
    8
    Dec 13, 2025
    Hi,
    This is a road with a 15% up slope, the leveled parking area is 90 degrees from it.
    Can the tractor with a 40' container do that backtrack parking maneuver safely?
    What is your maximum lateral incline acceptable value?
    What a general rule of thumb as far as the required maneuver radius distance for a 60' truck and container length to perform a 90 degree turn going backwards?
    Thanks
  3. Trucker61016
    Trucker61016 Road Train Member
    1,726
    4,915
    Sep 18, 2017
    Linville, Va
    What is Axetable?? Geeze
    Numb Thanks this.
  4. Big Road Skateboard
    7,899
    46,054
    May 2, 2021
    It's not a an Axetable, it's a Ptable, but you're using it with an axe.
    Golly gee, reading comprehension around here..
    I understood the question completely. OP, 8% is the answer. Good luck
    jaffles, albatros1952 and gentleroger Thank this.
  5. TurkeyCreekJackJohnson
    TurkeyCreekJackJohnson Medium Load Member
    621
    1,981
    Feb 7, 2024
    South Western US
    Pictures or it didn't happen. That's roughly 3 times the slope of most mountain highway downgrades. I'd be surprised if the tractor will be geared low enough. Weights also weren't provided either. Lots of seat of the pants math to do.
    W923, albatros1952 and Trucker61016 Thank this.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,171
    5,792
    Mar 18, 2021
    St Malo mb
    15% in reverse You will need to lock differentials or you’ll just spin especially if road is dirty or gravel.. I deliver into mountain jobsites and without 4 way locked up I tend to spin the drives..
    W923 Thanks this.
  7. abyliks
    abyliks Road Train Member
    4,302
    10,302
    May 2, 2010
    ludlow MA
    never measured them, but I’ve had plenty of hills in landfills where it was fully locked, first gear and the dozer will pull you the rest of the way when you stop
  8. W923
    W923 Road Train Member
    1,462
    4,560
    Feb 28, 2022
    In my opinion 15% is only going to work on dry concrete and since everything has 2xx gears now good luck to the clutch and driveline
  9. snowwy
    snowwy Road Train Member
    20,650
    13,374
    Jul 6, 2009
    I don't know what an acceptable angle is but I can definitely say if you're at an angle. The trailer will go to the downhill side.
    I had to fight that situation last week. Had to go on flatland. Back up and start over.
    Trucker61016 Thanks this.
  10. SmallPackage
    5,964
    19,250
    Dec 20, 2019
    Marion Texas
    The height of the fifthwheel plate from the frame rails and the forward position make a difference too. If Plate is lo pro and too close to top of rail and tires it will cause more twist and bottom out issues. Need to have fifth wheel slid all the way back so it doesnt let trailer bottom out on the tail ends of the rails or nose down into the cat walk or quarter fenders for the best results
