Maxxforce dt
Discussion in 'International Forum' started by dcwjr, Jan 8, 2014.
  1. dcwjr
    dcwjr Light Load Member
    58
    Jan 11, 2013
    Spn 520565 fmi:2 is active any clues??
  3. Heavyd
    Heavyd Road Train Member
    7,761
    6,200
    Feb 4, 2009
    This is a body controller code, not engine. It is for TEM AUX switch #2 data erratic or incorrect. Where and how are you reading this code?
    lv gn Thanks this.
  4. dcwjr
    58
    Jan 11, 2013
    We are pulling that from the dash- also have spn 94 fmi;1 spn 593 fmi31 spn597 fmi2 spn 1552 fmi2 spn 2000 fmi19 spn3976 fmi6 and multiple spn 520461/520590/520591 fmi9 these all inactive and intermittently engine light comes and barely runs shut it off sit and start back up and go
  5. Heavyd
    7,761
    6,200
    Feb 4, 2009
    94 - 1, Fuel pressure below normal
    597 - 2 Brake switch circuit fault, (they all have this, ignore it)
    1551 - 2 HVAC temp blend door stuck
    The last codes are all body controller. You are likely looking at a fuel pressure issue. It has been very cold in many areas that last few days. The least bit of water in the fuel is causing big problems all over. Try to change your filters and retest.
