Meritor PSI Inflation System Question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Otr Traveler, Nov 26, 2020.
  1. Otr Traveler
    Otr Traveler Bobtail Member
    42
    39
    Nov 19, 2020
    We have a stepdeck with the PSI System installed. Had the (stator?) replaced which cause the wheel end to leak air. The Stator had a dirty filter on the end. Why is this part causing an air leak? Has anyone else had this problem? BTW, parts for PSI systems seem difficult to find also. Glad to get it fixed,just wondered why it was leaking air on the wheel end.
  3. xsetra
    xsetra Road Train Member
    4,925
    6,583
    Aug 21, 2011
    I buy my parts from a local trailer dealer. Also I think fleetpride carries the parts.
    Reason for most leaks in the psi system is from the O-rings failing.
    Otr Traveler Thanks this.
