so my tractor parking valve started leaking air out of the non replaceable quick connect air line fittings.
So I called around and Freightliner wanted 242.00 for whole replacement valve.
So I started thinking about seeing if I could get it apart and replace the bad o-rings.
I ran down to harbor freight and bought a pick set to get the o-rings out.
While I was there I bought an assortment of the green high temp/ low temp o-rings also.
Here are some pics of how it went.
Everything back together and no leaks anymore.
All for less than 20.00 including the tools and a tube of lube.
My repair of a tractor parking/trailer supply valve
Discussion in 'Freightliner Forum' started by Hulld, Feb 11, 2017.
Page 1 of 3
Good stuff. Fixing things is becoming a lost art. Seems like everything is built to throwaway now.
nightgunner, clausland, Hulld and 1 other person Thank this. -
nice. hmm...i'm kinda envious of that oring set. is that wrong?
Hulld Thanks this. -
I've had mine go to leaking before when I couldn't get to a place to get O-rings. I just took it apart and smeared some grease on the O-rings and put 'er back together. No leaks. Good to go.
I bought a replacement valve a couple years back. Wasn't the same as the original. Directions said to route a hose out the back and loop around to another fitting and do something, and something and then something else.
I took it back for a refund. My valve leaks just a little sometimes. Wiggle the knobs and it stops.
I may try your solution. Thanks for posting.Hulld Thanks this. -
Everything including the o-ring assortment can be had at harbor freight for less than $20.00
HalpinUout and Trucker Dev Thank this. -
As far as I'm concerned, there's no need to spend the money on a new valve unless it physically breaks. And I've never seen one break. O-rings are easily replaced and it's good as new for a heck of a lot less money.
Upon further inspection of your pictures, my leak is from the knobs in front. Not the fittings in the rear.
I still might try it.Hulld Thanks this. -
silicone lube in spray can from Wal-Mart fixes quick connect leaks in 80% cases. time tested. but if o-ring is damaged bad it must be replaced.
Page 1 of 3
