My truck front differential is spitting gear oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 5K trucker, Sep 20, 2020.
  1. 5K trucker
    5K trucker Bobtail Member
    13
    4
    Sep 19, 2020
    Hi,Driver,my front gear box is spitting oil out from breather hole,I am losing 2 quart of oil every 12thousand miles,Can any driver help me with this problem, thanks,5k driver,
    Trucking Jobs in 30 seconds
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    2,972
    3,866
    Aug 26, 2014
    Strange! Could you possibly have air going into the axle housing from the interaxle lock air piston?
    Most use air to engage the lock but some are opposite.
  4. Heavyd
    Heavyd Road Train Member
    7,046
    5,116
    Feb 4, 2009
    Hmm. I'd like to see a picture of what you are talking about just so we are all on the same page. I have never heard of such of thing before.
  5. Michael 247
    Michael 247 Light Load Member
    220
    334
    Nov 20, 2017
    Va
    I've had it happen 1 time on a new Truck.. Somehow a plastic thread protector cap was left in the hole that the breather threads into..when the gear oil got hot it pushed oil through the breather..
    Dave_in_AZ Thanks this.
  6. 5K trucker
    13
    4
    Sep 19, 2020
    Thanks,Michael,I will take breather hole and replace a new one,see if that help,thanks,5k
  7. 5K trucker
    13
    4
    Sep 19, 2020
    This truck have air going to front differential,can it be solinoid inside differential?,thanks,Box Car Kidd
    BoxCarKidd Thanks this.
  8. 5K trucker
    13
    4
    Sep 19, 2020
    Is Frei
    Thanks,HeavyD,when I left home,I fill it full,then I drove 4500 miles,I lose more half quarts,truck run fine,the gauge of differential goes up to 210 most,I used full synthetic,I will bring it home and let Truck gear check it out,thanks,5k
  9. BoxCarKidd
    2,972
    3,866
    Aug 26, 2014
    I will am not going to that the time to explain how it works right now But this in how to check it.
    Remove the axle breather. Chalk the wheels and have the engine running brakes released. Everything like you are going down the road except in neutral. Is air being slowly pushed out the vent hole? No air no problem.
    5K trucker and Dave_in_AZ Thank this.
  10. haycarter
    haycarter Road Train Member
    1,441
    3,511
    Jun 9, 2012
    Australia
    Me Too..
    Heavyd and Dave_in_AZ Thank this.
  • Draft saved Draft deleted
