My truck front differential is spitting gear oil
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 5K trucker, Sep 20, 2020.
  1. lester
    2,819
    7,479
    Jan 2, 2012
    NW, Iowa
    Dang 210 seems kinda hot to me?? I've had mine spew some oil out when they get really warm
    5K trucker and Dave_in_AZ Thank this.
  3. Cattleman84
    Cattleman84 Road Train Member
    9,602
    67,009
    Nov 1, 2017
    The Sticks, Idaho
    How full are you filling it? You're not filling it through the breather hole are you? If you fill it clear to the breather hole that is WAY over full... And will spit alot of oil out as it heats up.
  4. dirthaller
    dirthaller Heavy Load Member
    937
    10,626
    Sep 22, 2011
    Coloratah
    My buddy bought some Schaefer’s that had “tack” additive in it. It started foaming out the breather hole. His mechanic told him to drain it and refill with “no tack” oil and it fixed the problem.
    5K trucker Thanks this.
  5. 5K trucker
    5K trucker Bobtail Member
    13
    4
    Sep 19, 2020
    Thank,Dirthaller,I fill it on side bolts, thanks,5k
  6. 5K trucker
    13
    4
    Sep 19, 2020
    Thanks,Lester,when I on step hill,it reach 210to 220,then temp drop down back to 180,the temperature at 100 degree outside,
  7. 5K trucker
    13
    4
    Sep 19, 2020
    Hi,HeavyD,here are some pix,thanks,5k trucker
    Heavyd Thanks this.
  8. 5K trucker
    13
    4
    Sep 19, 2020
    Thanks,BoxCarKidd,I just installed a new breather hose ,I will try your way tomorrow,thanks,5k trucker
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,879
    May 31, 2010
    West Harrison, In
    Hard to tell from picture, but breather should be on back side of axle. Road ram air will pressurize the housing. I sometimes run daycare at the shop!
    BoxCarKidd and 5K trucker Thank this.
  10. 5K trucker
    13
    4
    Sep 19, 2020
    Thanks,Spsauerland,my breather hose is front of differential on top,thanks,5k
  11. 5K trucker
    13
    4
    Sep 19, 2020
