N14 oil pan leak, repair or replace?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Sep 1, 2020.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,168
    1,544
    Dec 4, 2019
    Got an N14 Celect that’s in a ‘92 W9B. The oil pan has a crack about 2” to the side of the drain. It’s been patched in the past, with what looks to be JB weld. I can weld just about anything so, if it’ll clean up enough to allow me to do so then I’d try it. What do y’all recommend?
  3. bad-luck
    bad-luck Road Train Member
    3,023
    5,437
    Nov 16, 2013
    Baltimore, Maryland
    If you feel that you can weld it correctly, than do it, it will save you money. Otherwise replace the oil pan with a new one
    mile marker 27 Thanks this.
  4. kemosabi49
    10,008
    41,489
    Jan 13, 2013
    SW Arkansas
    If you can get all of the JB Weld off, then go for it. Drill a hole at the ends of the crack, then weld it up. May end up having to get another pan anyway but what the h...
  5. xsetra
    xsetra Road Train Member
    4,928
    6,588
    Aug 21, 2011
    It's already broke. Trying to fix yourself, can't break it any more.
    Save the money if you can.
    Good luck
    gentleroger and mile marker 27 Thank this.
  6. mile marker 27
    1,168
    1,544
    Dec 4, 2019
    I’ll probably drop it, wash it with soapy water, then use a small butane torch to burn any oil that may be in the crack. As suggested , I’ll drill out each end of the crack(s) then tig weld it. You guys by chance no the torque and torque sequence, for the pan?
