Need advice on gear ratio
Discussion in 'Experienced Truckers' Advice' started by MikeinTennessee, Mar 28, 2020.
  1. MikeinTennessee
    MikeinTennessee Bobtail Member
    11
    6
    Mar 28, 2020
    So can someone tell me the best way to gain a little more road speed. DD15 with 10 speed OD and 342 rears low pro 22.5 tires.To get 75 MPH I am turning 2100 RPM
    Trucking Jobs in 30 seconds
  3. x1Heavy
    x1Heavy Road Train Member
    34,029
    41,326
    Mar 5, 2016
    White County, Arkansas
    Take the Nanny off. Redline is 2150. Those low pros are not saving you much anyway.
  4. MikeinTennessee
    11
    6
    Mar 28, 2020
    Not to sound stupid but, will swapping to 11r 22.5 help much? And what do you mean take the Nanny off?
  5. x1Heavy
    34,029
    41,326
    Mar 5, 2016
    Many trucks are governed to a set speed. If you have taller tires that will help.
    Most trucks like to run close to 1600 RPM and that usually comes out to around the legal speed limit. I understand why low pros are on, however prefer the 24's I would not be surprised to see the situation improve if 24's are back on there.
  6. MikeinTennessee
    11
    6
    Mar 28, 2020
    Ok. The truck isnt governed to a certain speed. I just want to get the RPMs down and be able to run 75 or so and not be that high of an RPM. This was an old ATS truck so I am guessing it was probably geared to run at the 63 or so mark. That is right around the 1600 RPM range
  7. TripleSix
    98,064
    That’s impossible to do in the big hole with 3.42s and an 10 speed overdrive. I run a lower gear than you and don’t run anywhere near that high an rpm even past 85.
    @Superhauler, mind giving a 2nd opinion?
    AModelCat, Sani101, Lonesome and 6 others Thank this.
  8. larry2903
    larry2903 Medium Load Member
    604
    563
    Oct 18, 2009
    On the trails
    That’s a direct drive tranny, only way to get rpm’s down is swap tranny or gears.
  9. MikeinTennessee
    11
    6
    Mar 28, 2020
    Thats why I was wondering about swapping rears or tranny out. Not looking for 100 mile an hour truck. Just don't like that high RPM.
    650cat425 and jamespmack Thank this.
  10. x1Heavy
    34,029
    41,326
    Mar 5, 2016
    The ratio you gave is pretty powerful for pulling and I suspect that you want to keep that ratio.
    That leaves the transmission. However I don't know if it is possible to put in a transmission that will give you what you need at 75. It would be nice if you had a set of taller tires around to try it on and see if the speed situation improves versus your engine. 63 to 75 isnt that large.
    I don't have any more ideas anything else I would say would not mean much. And that comes from a thought that the truck is useful to you and you want to keep using it.
    Edit just read your response. No one is looking for 100 either. 75-80 is plenty. And you will have enough RPM's on hand to take on the smaller hills or deal with headwinds etc.
  11. Mid-May Trucker
    Mid-May Trucker Road Train Member
    1,034
    1,895
    Oct 23, 2018
    I think you bought a truck that was made for 60 miles an hour
    Crete?
    Rideandrepair Thanks this.
  • Draft saved Draft deleted
