Need dot consultant? Dot advice
Discussion in 'Trucking Industry Regulations' started by iamdot, Apr 29, 2009.
  1. iamdot
    iamdot Bobtail Member
    26
    Apr 29, 2009
    brandon,fl
    Hey all you truckers! I am a recently retired DOT compliance officer looking to assist all you with your DOT Compliance needs. The penalties are getting out of hand and you don't need to pay costly fines when the compliance is so easy! FEEL FREE TO ASK!!!:biggrin_25514:
  3. psanderson
    psanderson Road Train Member
    1,029
    402
    Oct 13, 2008
    Moline, Illinois
    Welcome Aboard!
    From a retired federal DOT official
  4. driver1189
    driver1189 Bobtail Member
    22
    8
    Oct 29, 2008
    sevenmile,oh.
    why can't we tint our windows and cars can? i got a 85 dollar fine for it.
  5. psanderson
    1,029
    402
    Oct 13, 2008
    Moline, Illinois
    I'll answer that.
    See 49 CFR part 393.60(d) in your motor carrier safety rules book. Window tinting is allowed but with certain restrictions. These restrictions also apply to automobiles in most states however the tinting for autos is controlled by the states over and above the federal National Highway Traffic Safety Commission. Commercial vehicle tinting is controlled under the above rule.
    Apparently your tinting was more than allowed under this rule.
  6. psanderson
    1,029
    402
    Oct 13, 2008
    Moline, Illinois
    Here's the rule:
    TITLE 49
    TRANSPORTATION
    CHAPTER III
    FEDERAL MOTOR CARRIER SAFETY ADMINISTRATION
    DEPARTMENT OF TRANSPORTATION
    PART 393
    PARTS AND ACCESSORIES NECESSARY FOR SAFE OPERATION
    Table of Contents Subpart D
    Glazing and Window Construction
    Sec. 393.60 Glazing in specified openings.
    (d) Coloring or tinting of windshields and windows. Coloring or tinting of windshields and the windows to the immediate right and left of the driver is allowed, provided the parallel luminous transmittance through the colored or tinted glazing is not less than 70 percent of the light at normal incidence in those portions of the windshield or windows which are marked as having a parallel luminous transmittance of not less than 70 percent. The transmittance restriction does not apply to other windows on the commercial motor vehicle.
    Jimmbuds, Roetaw and KnoxFox23 Thank this.
  7. dr5169
    dr5169 Medium Load Member
    324
    97
    Dec 1, 2008
    chicago,il
    I am glad both of yu guys are on here ..i will have many questions coming up here in the very near future..Psanderson your post's have been very informative.!!!
  8. dr5169
    324
    97
    Dec 1, 2008
    chicago,il
    What is the difference between a 3rd 2nd and 1st level inspection. ??
  9. TprDave
    TprDave Bobtail Member
    8
    23
    Feb 20, 2009
    New England
    LEVEL I
    North American Standard Inspection – An inspection that includes examination of driver’s license; medical examiner’s certificate and Skill Performance Evaluation (SPE) Certificate (if applicable); alcohol and drugs; driver’s record of duty status as required; hours of service; seat belt; vehicle inspection report(s) (if applicable); brake systems; coupling devices; exhaust systems; frames; fuel systems; lighting devices (headlamps, tail lamps, stop lamps, turn signals and lamps/flags on projecting loads); securement of cargo; steering mechanisms; suspensions; tires; van and open-top trailer bodies; wheels, rims and hubs; windshield wipers; emergency exits and/or electrical cables and systems in engine and battery compartments (buses), and HM/DG requirements as applicable. HM/DG required inspection items will be inspected by certified HM/DG inspectors.
    LEVEL II
    Walk-Around Driver/Vehicle Inspection – An examination that includes each of the items specified under the North American Standard Level II Walk-Around Driver/Vehicle Inspection Procedure. As a minimum, Level II inspections must include examination of: driver’s license; medical examiner’s certificate and Skill Performance Evaluation (SPE) Certificate (if applicable); alcohol and drugs; driver’s record of duty status as required; hours of service; seat belt; vehicle inspection report(s) (if applicable); brake systems; coupling devices; exhaust systems; frames; fuel systems; lighting devices (headlamps, tail lamps, stop lamps, turn signals and lamps/flags on projecting loads); securement of cargo; steering mechanisms; suspensions; tires; van and open-top trailer bodies; wheels, rims and hubs; windshield wipers; emergency exits and/or electrical cables and systems in engine and battery compartments (buses), and HM/DG requirements as applicable. HM/DG required inspection items will be inspected by certified HM/DG inspectors. It is contemplated that the walk-around driver/vehicle inspection will include only those items, which can be inspected without physically getting under the vehicle.
    LEVEL III
    Driver/Credential Inspection – An examination that includes those items specified under the North American Standard Level III Driver/Credential Inspection Procedure. As a minimum, Level III inspections must include, where required and/or applicable, examination of the driver’s license; medical examiner’s certificate and Skill Performance Evaluation (SPE) Certificate; driver’s record of duty status; hours of service; seat belt; vehicle inspection report(s); and HM/DG requirements. Those items not indicated in the North American Standard Level III Driver/Credential Inspection Procedure shall not be included on a Level III inspection.
    LEVEL IV
    Special Inspections – Inspections under this heading typically include a one-time examination of a particular item. These examinations are normally made in support of a study or to verify or refute a suspected trend.
    LEVEL V
    Vehicle-Only Inspection – An inspection that includes each of the vehicle inspection items specified under the North American Standard Inspection (Level I), without a driver present, conducted at any location.
    LEVEL VI
    North American Standard Inspection for Transuranic Waste and Highway Route Controlled Quantities (HRCQ) of Radioactive Material – An inspection for select radiological shipments, which include inspection procedures, enhancements to the North American Standard Level I inspection, radiological requirements, and the North American Standard Out-of-Service Criteria for Transuranic Waste and Highway Route Controlled Quantities (HRCQ) of Radioactive Material.
    As of January 1, 2005, all vehicles and carriers transporting highway route controlled quantities (HRCQ) of radioactive material are regulated by the U.S. Department of Transportation and required to pass the North American Standard Level VI Inspection. ​
    Previously, U.S. Department of Energy (DOE) voluntarily complied with the North American Standard Level VI Inspection Program requirements.
    Select radiological shipments include highway route controlled quantities (HRCQ) of radioactive material as defined by Title 49 CFR Section 173.403. And, because only a small fraction of transuranics are HRCQ, DOE has decided to include its transuranic waste shipments in the North American Standard Level VI Inspection Program.
    LEVEL VII
    Jurisdictional Mandated Commercial Vehicle Inspection – An inspection that is a jurisdictional mandated inspection program that does not meet the requirements of any other level of inspection. An example will include inspection programs such as, but not limited to: school buses; limousines; taxis; shared ride; hotel courtesy shuttles, and other intrastate/intraprovincial operations. These inspections may be conducted by CVSA-certified inspectors, other designated government employees or jurisdiction approved contractors. Inspector training requirements shall be determined by each jurisdiction. No CVSA decal shall be issued for a Level VII inspection but a jurisdiction-specific decal may be applied
  10. dr5169
    324
    97
    Dec 1, 2008
    chicago,il
    and if you get a violation then yu pay the fine...does anything go on your driving record
  11. TprDave
    8
    23
    Feb 20, 2009
    New England
    I can't answer for all the states, but we write the infraction to the company if its an equpiment violation and the driver if its a driver violation like a logbook etc...
    So only the driver violations that you get a ticket for are the ones you have to worry about, getting points for:biggrin_25521: But again each state is different!!
    dr5169 and BurmaBoy Thank this.
