Need help shopping for a 2nd fridge for my sleeper
Discussion in 'Experienced Truckers' Advice' started by lonewolfgringo, Oct 5, 2026.
  1. lonewolfgringo
    lonewolfgringo Light Load Member
    56
    146
    Feb 10, 2026
    i'm trying to lose weight and trying to reduce my eating expenses as an OTR solo company driver. i recently got moved into a new company truck, a 2027 cascadia and it has a nice big fridge that came with it.
    i purchased a second fridge that i have ratched strapped to my top bunk to fill up with cottage cheese because im experimenting with a cottage cheese diet. basically cottage cheese and quinoa is the base and i mix other food with it to have a balanced diet.
    anyway i got this absorbtion fridge on amazon for the top bunk. im on vacation and kept the truck in opti idle all night and when i checked a thermometrr i got from walmart that i left in the fridge it read 36 degrees. but when i returned to the truck this afternoon to fill up that second fridge the temp read 60 degrees.
    there are to wall outlets. one for a microwave i got and another on the side of my bed. i plugged the absorbtion fridge into an extention cord and then plugged that cord into the same outlet my microwave is in.
    i got lucky and was able to fit all but two of the 16 cottage cheese tubs i got into the factory fridge but it cant hold much else because of this.
    i checked the temp of the 2nd fridge again one hour after i unplugged it from the microwave outlet and instead plugged it into a powerstrip that is plugged into the 2nd outlet on the side of my bed, where i also plug my CPAP into. the temp now reads 55 degrees.
    so i think i may have gotten the wrong fridge for this.
    for you more experienced truckers out there, should i be getting a compressor fridge instead? if so which one do you reccomend and how do i solve the water issue? how would i keep water from spilling when im on the road?
    here is the model number of the absorbtion fridge that i got: HSG-40B2U-P-FBM
    blairandgretchen and Chinatown Thank this.
  3. Moosetek13
    Moosetek13 Road Train Member
    15,215
    19,505
    Nov 1, 2010
    Burnsville, MN
    It's always best to do the homework and studying before taking the test.
    ESAFO Thanks this.
  4. Chinatown
    Chinatown Road Train Member
    79,364
    193,020
    Aug 28, 2011
    Henderson, NV & Orient
    Maybe go to an RV dealership and ask those questions.
    Puppage Thanks this.
  5. lonewolfgringo
    56
    146
    Feb 10, 2026
    wow this forum is useless. nothing but trolls here
  6. Ddh77777
    Ddh77777 Medium Load Member
    494
    987
    May 28, 2025
    I just wouldn't hold that much perishable stuff at once, honestly. If you have a breakdown or something and you're out of the truck for a few days you're probably gonna have to throw a lot of it out. Or pack it all up and hope the hotel you're in will let you use theirs.
    Speedy356 Thanks this.
  7. Big Road Skateboard
    7,999
    46,887
    May 2, 2021
    Hey @Marcus Reid, ain't this your wheelhouse here?
    Surely you'd rather talk trucker gear than fuel prices, especially since you do all these reviews...
    blairandgretchen and Razororange Thank this.
  8. Chinatown
    79,364
    193,020
    Aug 28, 2011
    I wasn't trolling you. Sometimes truckers go to RV dealerships when they can't get satisfactory results otherwise.
    RV dealerships know all about refrigeration units because so many people travel in RV's and some live in RV's full time.
    One trucker on this forum went to an RV dealership because he wanted a roof mount air conditioner for an older truck. He went there and they knew exactly what to do and installed a roof mount air conditioner. Some have installed, not only refrigerator, but separate freezer units designed strictly for RV's and small enough for sleeper trucks.
    Ddh77777 Thanks this.
  9. Chinatown
    79,364
    193,020
    Aug 28, 2011
  10. gentleroger
    gentleroger Road Train Member
    8,233
    22,664
    Jun 1, 2010
    I had no idea what an absorption fridge was so I googled it. Took me all of 60 seconds to figure out an absorption fridge is a bad choice for a CMV and an abysmal choice for a top bunk fridge. They need to remain level, require good ventilation, and tend to be power hogs when run on electricity. Hence Moose's response about doing your homework.
    Looking at the specific model on Amazon, every red flag is out. Almost all the one star reviews list "it won't cool on AC". The product description says it draws less than 1 kwh per day, at 12 volt 15 amp appliance running for 24 hours will draw more than 4 kwh per day. 110 volt 15 amp is about 30 kwh per day - call it 1,200 watts continuous. In my experience any appliance drawing more than 1,000 watts off the inverter needed the apu or the main engine running. The killer is in the manual "12 volt power will only maintain the temperature".
    Going to the RV/boater forums (who have a lot more experience with these things, hence Chinatown's response) and they all say absorption fridges suck.
    I would be returning this if possible.
  11. buzzarddriver
    3,953
    12,370
    Feb 1, 2011
    Dallas, TX
    When a $100 fridge would have worked just fine.
    Magoo1968 Thanks this.
