Need help trying to figure out how this guy folds his tarps
Discussion in 'Flatbed Trucking Forum' started by Michael91184, Dec 30, 2015.
  1. Michael91184
    Michael91184 Light Load Member
    Jun 23, 2015
    51
    Thanks Received:
    43
    Youngstown, Ohio
    i've been driving since August and one thing i can say so far that has cost me some time is tarp folding. I found a video off youtube on a guy showing how fast it takes him to fold his tarps, but he didn't show the initial setup, I thought I knew how it was done but it ended up costing me time. Can anyone iterate on this method, or another possible solution?
    TheDude1969, 281ric, Hurst and 2 others Thank this.
  2. breadtrk
    breadtrk Heavy Load Member
    Oct 4, 2015
    788
    Thanks Received:
    823
    Looks pretty thorough. That is how I did it for 20 years. What exactly is your question?
  3. Michael91184
    Jun 23, 2015
    51
    Thanks Received:
    43
    Youngstown, Ohio
    can you possibly explain how its done? shed some light on how you set it up.
    MJ1657 Thanks this.
  4. breadtrk
    Oct 4, 2015
    788
    Thanks Received:
    823
    Put the bungie hook in the corners, hooked to the trailer. It is pretty clear in the video the rest.
    Sorry but I still don't understand what you mean by setup? The video couldn't be more clear.
  5. passingthru69
    Jul 12, 2009
    8,740
    Thanks Received:
    34,849
    davenport,Ia / ratchaburi, thailand
    Ok what lacks is the first part. You have your tarp layed out and you grab one end and go to center of tarp. Then go to the other side and repeat. Then fold the side over and repeat the other side then follow his steps. easy
    281ric and Hurst Thank this.
  6. Espressolane
    17,464
    Thanks Received:
    106,717
    This is what I know as a rail fold.
    The tarp he is folding in the video is a steel or 4 foot drop.
    This is can be done inside or outside depending on where you want your edges to be.
    I usually do an outside.
    Lay your tarp out flat on the ground.
    Hook a bungee to a point on the trailer.
    Hook the grommets or D rings at the 4 foot point.
    Go to other end and grab hold of the tarp at the same place as the bungee, pick up and give a little shake and pull a it. It should look like an M at this point. Wave it back and forth once or twice and flip it in half. Go take the end off the bungees on the trailer and fold and roll.
    Takes like 5 minutes all together.
    Michael91184 and Hurst Thank this.
  7. Hurst
    Hurst Registered Member
    Aug 24, 2011
    6,618
    Thanks Received:
    12,266
    Tampa, Fl
    That is the cats meow right there.
    I'm going to try that the next time I fold my tarps. I've been doing it the hard way, doing it on the ground going from front to back. That looks really simple. I seriously need to learn how thats done.
    Thank you for showing this video.
    The only thing I dont understand is how he got the second fold before he rolled it up? I mean if you pull on it,.. I can see the single fold,.. but how would that work on a 26' long with 8' drop? I have multiple folds before I roll mine up.
    Anyone?
    Hurst
  8. Hurst
    Aug 24, 2011
    6,618
    Thanks Received:
    12,266
    Tampa, Fl
    Excellent explanation. Thank you very much.
    Can this be done with a lumber tarp or 8ft drop?
    Hurst
  9. MJ1657
    MJ1657 Road Train Member
    Jan 28, 2012
    7,521
    Thanks Received:
    50,151
    Isanti, MN
    This could actually be an interesting thread.
  10. TampaTony
    TampaTony Medium Load Member
    Dec 13, 2015
    322
    Thanks Received:
    340
    I wish I had a easy way to fold my tarps, I have the worst tarps. I think they are designed for hay loads. The brand on them is Montana canvas. Basically it's a three tarp system meant to spand my 53ft flat bed. They are kicking my ### more then ever now that they are frozen with snow and mud.
