Need info on overhad clearance in PA
Discussion in 'Experienced Truckers' Advice' started by DragonHalo99, Mar 21, 2015.
  1. DragonHalo99
    DragonHalo99 Light Load Member
    176
    25
    Apr 29, 2013
    Columbus, OH
    Guys I drive for central refirgerated (swift) on their kraft dedicated division. Well this is a first but My load that I am pulling now is a 14ft 3in trailer and I need to get it to the kraft plant in bethlehem pa. I am taking I-70 atm to 76 and 76 to 81 then 78 towards bethlehem. I have done loads thru pa before and I swear there are places you cant clear with a 14ft trailer I cant remember where though. I am googleing right now and not getting anything usefull for overhead clearance in pa. Most usefull thing I have is my 2014 rand mcnally road atlas. Would someone know if I will run into issues with this 14ft 3im swift reefer on my current route? A online map of bridge clearances helps too. Normally I would be pulling a regular 13-6 53foot central reefer, which is why I say its a first having a reefer taller than 13-6.
  3. Ducks
    Ducks "Token Four-Wheeler"
    3,415
    3,581
    Jan 1, 2007
    Southeastern Pennsylvania
    I don't drive a truck, but I found this on-line at http://§http://www.dmv.state.pa.us/pdotforms/vehicle_code/chapter49.pdf. Does this mean you need a permit for that trailer?
    bullhaulerswife Thanks this.
  4. zinita17601
    zinita17601 Road Train Member
    1,274
    1,519
    Aug 19, 2010
    lancaster pa
    Never heard of such a thing,to pull a load that high you need permits,a pole car.did u take your medecine this morning?
    G.Anthony Thanks this.
  5. Hammer166
    6,946
    23,887
    Aug 18, 2007
    ~8600+' and loving it!
    You need to call dispatch and raise hell until someone comes to their senses. You go over there with that tall of a trailer, and it's gonna be an open-top before you're through!
  6. baha
    baha Road Train Member
    4,137
    2,834
    Jul 25, 2013
    ga
    Must be a hi/cube trailer that is pulled by a truck with smaller wheels an tires,19.5
  7. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    745
    Aug 27, 2012
    Austin, TX
    Personally I think this is nothing more than a TALL story.
    lmcclure1220 and G.Anthony Thank this.
  8. STexan
    STexan Road Train Member
    14,962
    29,144
    Oct 3, 2011
    Longview, TX
    Me smells a rat. I've seen 14' dry vans but 14'3 reefer? And dispatched into PA? I think 14'6 can clear the bridges, but some you may want to run the inside lane. Anything over 13-6 require permit on PA Turnpike
  9. DragonHalo99
    176
    25
    Apr 29, 2013
    Columbus, OH
    Its a 14-3 reefer says on the trailers cab card. Dispatch didn't believe me so I grabbed the terminal manager at the columbus yard. Now dispatch is trying to figure out why a private fleet trailer got loaded. They are cross docking it atm onto a central reefer.
  10. Hammer166
    6,946
    23,887
    Aug 18, 2007
    There are 14' reefers out west. And 14'6" can clear some bridges but I can promise you if I went over there that tall I'd likely have a convertible!
  11. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,561
    Jul 15, 2006
    El Chuco, Tejas
    I've seen some Stevens Transport trailers that were 14'
