Need info on what Cat manual to get for 3406
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BronsonA14, Nov 9, 2024.
  1. BronsonA14
    BronsonA14 Bobtail Member
    5
    5
    Oct 30, 2024
    I have a 4CK 3406C in my truck. It was originally a PEEC and previous owner had mechanical pump and timing advance put on. I’m trying to figure out what repair manual I need to get that would cover the info for pump and advance. Rather not spend several hundred dollars on one through Cat so just a matter of finding the right one online. Would one for 4MG, 2EK or any other prefix get me the info I need? The one I found for 3406B 4CK appeared to be for PEEC engine
  3. wore out
    wore out Numbered Classic
    14,941
    180,408
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    If you are gonna order parts out of it you gotta stick with 4CK. If you are just wanting diagnostic help and repair procedures most any of them will work. The rod bolt torque would be the difference in a 4MG and a 4 CK. The 4MG uses the small rod, 4CK uses the big rod. It would suck not to know that
    Oxbow, beastr123 and W923 Thank this.
  4. Diesel Dave
    8,111
    19,816
    Jan 20, 2010
    Hesperia, Ca.
    Look on eBay, long shot.
    Oxbow Thanks this.
  5. BronsonA14
    5
    5
    Oct 30, 2024
    I’m wanting repair info on the pump and timing advance for now. Not anything else. So according to what I’ve read, a manual for a PEEC engine will not give me that info. So I need to correct one for a mechanical pump.
    Oxbow and wore out Thank this.
  6. wore out
    14,941
    180,408
    Jun 5, 2013
    Yea
    but where did they get the mechanical pump from?
    Oxbow, beastr123 and AModelCat Thank this.
