New guy, First truck. Need some engine advice! 3406E power.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by double brew, Mar 7, 2015.
  1. double brew
    double brew Light Load Member
    76
    20
    Mar 7, 2015
    code on the engine tag says 1lw 435hp 450 hp.
  3. 2CAN
    2CAN Medium Load Member
    613
    2,756
    Jan 7, 2010
    any idea where a guy could get this 550 file? I cant seem to find anybody that will flash my 5ek.
    Thanks
  4. Diesel Dave
    8,687
    24,721
    Jan 20, 2010
    Hesperia, Ca.
    I only do my own. I sent you a PM
    2CAN Thanks this.
  5. Diesel Dave
    8,687
    24,721
    Jan 20, 2010
    Hesperia, Ca.
    I bought my turbo from turbo supply. I gave them 5 borg wagner part number's and they shipped it to me and I put the turbo together. Cost around $1,500 about 3 years ago with shipping. I don't have a SIS so I don't know what injector's you have.
  6. double brew
    76
    20
    Mar 7, 2015
    Well, I checked for boost leaks, and came up with none. So, now that leaves to question if the 900* cruising temperature will be a problem or not.
    I have a date set up to get it turned to 550-1850.
    And, as far as the jake brake sound issue. I knew something was out of whack, and it is.. I need to re-run the top end on it. the NO 5 cylinder jake brake rod or whatever its called is the only one that doesnt have a gap in it when idling. I pressed in the solenoids on the 3 packs (1-2, 3-4, 5-6) and the first 2 solenoids pop, then mellow out the jake sound. The 5-6 pack is the only one that pops and keeps popping loudly. So, after running the overhead, and getting the ecm reset, hopefully that will solve a few of my questions I have about things.
    tsavory Thanks this.
  7. rank
    rank Road Train Member
    9,918
    113,503
    Feb 11, 2010
    Still waiting to see what your boost is.
    In the summer, I run a 425 hp 3406 pulling 80,000 in the Northeast. Mine is a B model so there is no ECM. IIRC it makes 25 psi boost which probably means someone has played around with it a little bit because I was told the 425 made ~18 psi stock. Ambient air is usually 75 to 90 degrees F and the only time I get to 900 on the pyro is when I'm pulling a good hill. It will get alot hotter than that if I let it.
    I wouldn't be comfortable cruising at 900.
  8. double brew
    76
    20
    Mar 7, 2015
    Yeah, boost gauge hasnt come in yet. Kinda irritating, but I have a page worth of other little fixing crap I'm currently doing. I wanted to get the boost gauge in before I got it turned up. So HOPEFULLY, I can get the overhead run and the gauge done next weekend before I bring it over there. I asked the guy thats turning it up about the exhaust temp, and he said to check for boost leaks. Thats the furthest I got with him on that subject before he left for the weekend.
  9. double brew
    76
    20
    Mar 7, 2015
    BTW, I love your flat top.
    rank Thanks this.
  10. rank
    9,918
    113,503
    Feb 11, 2010
    Yeah. I blew a CAC boot one time on a '98 M11 Celect Plus and the pyro needle twisted around like the tach on a crotch rocket.
  11. tony97905
    tony97905 Road Train Member
    1,023
    12,241
    Feb 28, 2015
    Land of Ahhhhhs
    Verify pyrometer gauge accuracy first...it could be off a considerable amount and cause you to chase your tail looking for a fix to something that isn't an issue. Since this truck has some age on it I would also give serious consideration to replacing the flexible fuel lines, especially the suction side....this can cause serious performance issues along with causing people to spend money with FASS, Fuel Preporator, etc that only males the air bubbles smaller by pressurization.
