New guy split shift
Discussion in 'Questions From New Drivers' started by WrongWay30, Mar 30, 2018.
  1. WrongWay30
    WrongWay30 Bobtail Member
    24
    5
    Apr 21, 2011
    Minnesota
    I'm traing a driver tomorrow how to shift a 10 speed. Just high and low. He needs a refresher since his truck is an auto. Any pointers? Downshift rpms and speeds. Upshifting should be good. It's the 9th-5th downshift I'm worried about. Ex. Highway speed to clover leaf to yield sign with no one there. Anyone have a cheat sheet with engine speeds and road speeds? Any help is appreciated
  3. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    For high range, add first and last number of road speed to determine correct gear.
    35mph? 3+5=8th gear will drop in. 25mph? 2+5=7th gear will drop in.
    Low range - 5th gear RPM = road speed X100. Road speed 10mph? 5th gear will need to see 1000rpm to drop in.
    If in doubt and confused, go for 6th. 6th will usually drop in easily between 10 and 20mph.
    Don't bother shifting to low range unless you're coming to a complete stop. And even then, don't downshift through low range. Brake until you bog it down in 6th, then clutch. Shift to low range and your starting gear after you're stopped.
  4. dptrucker
    dptrucker Road Train Member
    4,681
    3,197
    May 14, 2012
    adelanto,ca.
    If you do not know how to shift... how can you train someone ?
    Streetroddreams and windsmith Thank this.
  5. tinytim
    tinytim Road Train Member
    5,143
    18,250
    Oct 29, 2007
    Northern Ontario
    Any chance you work for a small mom and pop, one of those places that's real hard to get into with weekends off, home daily and starts out around 80k? If so it may be more than a 'refresher'. :biggrin_2559:
    Offered a great paying job close to home, but manual trucks only.
  6. Dakota1358
    Dakota1358 Medium Load Member
    431
    502
    Jun 15, 2009
    Staunton,Va
    Took the words right out of my mouth
    Ranger309 and dptrucker Thank this.
  7. Lav-25
    Lav-25 Medium Load Member
    565
    897
    Mar 31, 2018
    See above for down shifting a 10 speed. 6 th gear , bog, stop , start all over. If doing a cloverleaf or turn onto road, slow down too 6,possibly 5 if heavy , and start working it up. If light to light then youll be doing some work, or skip it if its light enuf.
  8. Ridgeline
    22,375
    116,088
    Sorry but he should have been taught how to figure out how to shift a transmission before he got a cdl.
