I noticed this new KW parked on I-70w in Indiana, comming from Ohio assembly plant, the frame looks simply bolted no rivets or special hex chassis fasteners. Doesn't lose the elasticity ?
New Kenworth chassis bolted not riveted !?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Johny41, Sep 16, 2018.
Page 1 of 6
Mattflat362 and x1Heavy Thank this. -
They can be ordered either way.
Most are “buck bolted” but you can order them with just regular bolts too like you see there.Oxbow, Johny41, Dave_in_AZ and 1 other person Thank this. -
Those drive tires are flawed, look at the inside ones at the shoulder edge of the treads. I see thick cuts all the way down to what is essentially recap country.
The frames on those pictures are pretty. Just the way I like em. -
I've honestly never seen a KW with huck bolted frames (I have 1 and a couple relatives have had 8 or 9 between them). None of them were huck bolted as far as I can remember.
Oldironfan, adayrider, x1Heavy and 3 others Thank this. -
Mattflat362, x1Heavy, Johny41 and 2 others Thank this.
We just got a new KW a couple weeks ago. I’ll have to look closer at it?
I'd think that hand torqueing all those bolts would be more expensive than the machine that snaps the rivet off when at torque.
Johny41, x1Heavy, Oxbow and 1 other person Thank this. -
That being said.......I completely get the universal aspect of bolts. Plus you dont have to get the smoke wrench out to remove them if needed down the road. Pick your poison. Catch 22.Mattflat362, Johny41, Oxbow and 3 others Thank this. -
Definitely better for a "field repair" being able to just zip the bolts on and off. Those huck guns ain't cheap. Even a tiny one to do the cab on my KW is worth more than the labour for a body shop to redo all the cab ones.
Oxbow, Dave_in_AZ and spsauerland Thank this.
Page 1 of 6
