No power. Poor fuel economy.
Discussion in 'Volvo Forum' started by Amram, Aug 27, 2018.
  1. Socal Xpress
    1,855
    1,957
    Dec 6, 2014
    Los Angeles, Ca
    Not true..... maybe the shops you dealt with.
  3. Amram
    Amram Medium Load Member
    448
    234
    Feb 4, 2017
    It came with a 10 speed manaul. I swapped in a similar ratio 13 speed to gain the splits.
    KB3MMX and x1Heavy Thank this.
  4. 25(2)+2
    18,693
    43,198
    Sep 18, 2006
    the road less travelled
    Did that affect performance immediately, or has it gotten worse lately?
    x1Heavy Thanks this.
  5. Amram
    448
    234
    Feb 4, 2017
    No it didn't affect it at all it just recently got crappy
    KB3MMX Thanks this.
  6. bavarian
    bavarian Heavy Load Member
    727
    781
    Feb 13, 2014
    Winnipeg
    Did you start at the basics? Air filter, fuel filter, restricted flow from tank? Does one of the tanks drain faster than the other?
    How about your shifting habits. Those engine are low rpm engines. They perform best at their torque range. 1200-1400 rpm.
  7. Amram
    448
    234
    Feb 4, 2017
    Stop my shifting habits because it just recently lost 3 miles per gallon lifetime fuel efficiency of this truck with me driving it has been 7.9. It just had to be serviced done 2 weeks ago and the driver side fuel tank drains faster than the passenger side tank
    KB3MMX Thanks this.
  8. Amram
    448
    234
    Feb 4, 2017
    Oh and over the weekend I had the engine smoke tested to check for leaks I can hear something that sounds like a leak coming from the EGR side but it doesn't come up during the smoke test because they waited until the engine is cold but when the engine is hot when I lose power
  9. bavarian
    727
    781
    Feb 13, 2014
    Winnipeg
    Check your boots from turbo to intercooler and back to the mixer housing. Spray them with soapwater. There is an O-ring on the driver side where the elbow coming from the intercooler is attached to mixer housing. This O-ring does sometimes break. There is also a notch in there to hold the elbow in place. I had it broken off on a truck before which let the elbow move and tore the boot apart.
    Find out why your tanks don't drain equally. You do have a problem in that area. The engine might duck fuel from one tank only and not get enough juice.
    Good luck
  10. Amram
    448
    234
    Feb 4, 2017
    I have replaced those vent filters in the past 6 months. I said to hell with them this weekend and just unplugged them. Next step is replace the fuel lines. Volvo in Nashville thinks I might need to replace the fuel filter assembly on the driver side with the spin on since I have 656k miles on the original. The truck is on its 9th set of injectors.
    Bakerman and KB3MMX Thank this.
  11. bavarian
    727
    781
    Feb 13, 2014
    Winnipeg
    9 sets of injectors in less than 700k miles does tell a story.
    Find the issue fast before throwing more parts at it or do as advised before: SELL IT, FAST.
    KB3MMX Thanks this.
