Noise under acceleration
Discussion in 'Freightliner Forum' started by clivusmul, Jan 15, 2012.
  1. clivusmul
    clivusmul Bobtail Member
    MESA
    Posting this to the Freightliner forum as well...I am a new forum member owing 3 2007 Freightliner CL120s.
    One of my 3 trucks with 610K miles has a new Turbo charger installed 6 months ago. Engine is DD Series 60, 14 ltr, setup for 525HP/1650 lb-ft torque. My driver reports hearing a new noise today ONLY if the unit is under fairly hard acceleration. Noise appears to be coming from the exhaust/EGR and/or engine control items. It is not a fan, bearing or H2O pump issue. Also is not the Air pump or PS items... Driver reports no problems with developing power. Oil consumption is normal. There is no abnormal stack smoke either under any power condition. Starts fine/idles fine. Under constant speed, engine sounds "normal". However, if the tractor is pulling a hill using extra "foot" throttle, or if the speed control causes the engine to produce more power, a fairly severe "rattle" or loud abnormal "noise" is heard. When acceleration stops or load is overcome by speed or flat ground, noise goes away... Could this be an EGR valve problem? I am at or near Oklahoma City today and wonder if I can "limp" back to Mesa Arizona to repair and/or diagnose... As it is Sunday, I have no ability to read any engine computer codes or see a technician. All suggestions or similar solutions found are welcome. Thanks, Clivusmul/RBJ Mesa, Az
  3. whats in a name?
    whats in a name? Bobtail Member
    23
    Jan 15, 2012
    Effingham, IL
    my 99 classic had a noise only during acceleration and it ended up being the passenger side muffler. the top of the muffler had a crack and the inner tube was loose. replaced the muffler and the sound went away
  4. HydraC24
    HydraC24 Bobtail Member
    I'm having the same issue. Did you ever find out what was the problem?
  5. Celina
    Celina Bobtail Member
    19
    8
    Feb 9, 2020
    I’m having a problem with some buzzing noise. It sounds like a bunch of bees. Do you know if it was a likely noise ?
  6. Dave1837
    Dave1837 Road Train Member
    1,398
    4,342
    Nov 16, 2019
    Pennsylvania
    Engine mount possibly?
  7. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    he stopped visiting the website in 2012 when the thread was created
  8. Dave1837
    1,398
    4,342
    Nov 16, 2019
    Pennsylvania
    Whoops lol it showed up in my new posts
    Chubby Fly Thanks this.
