Not having APU in swift like?
Discussion in 'Swift' started by crazybread, Aug 6, 2015.
  1. crazybread
    crazybread Medium Load Member
    312
    58
    Jul 30, 2015
    Hello I am currently thinking about becoming a truck driver and want to know how is it like working for a company that does not have APU? In order to have the AC on when it is in the summer time do you have to idle all night long? If so i thought there was anti idle laws that you can not idle at night time? Does swift get mad at you if you idle at night?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    Swift will always complain about idle times.
    I will always ignore the complaints.
    After 4.5 years nothing has changed either way.
    DocWatson, tucker and HousTank Thank this.
  4. dodgeram440rt
    dodgeram440rt Heavy Load Member
    840
    601
    May 19, 2009
    Piqua, Ohio
    Moose is right, if it's hot out, idle the truck. Swift understands we need to be comfortable to get the rest we need to be safe drivers. They really don't have a problem with idling they trucks when it is necessary. What they do have a problem with is excess idling and idling when it isn't necessary. My DM told me one time he walked with a driver out to his truck and the truck was idling...while the driver was inside the terminal. That is unnecessary.
    As for the illegal issue, in 5 1/2 years out here, I have never seen a law officer cruising the truck stops to see who is idling. If they did, they would make a killing in fines or need a bus to haul 100 plus drivers off to jail because when it's hot, EVERYONE is idling. And the same when it's cold. Yes, the truck has bunk heaters that work remarkably well (most of the time), but I got several messages last winter that said to idle when temps are below 15 degrees.
  5. austinmike
    98,446
    no apu, you idle the truck if its hot or cold. Never seen any Idle Police at any truck stop.
  6. blsqueak
    blsqueak Road Train Member
    3,988
    3,284
    Dec 27, 2009
    buckeye lake, oh
    I have seen the local at the Pilot in Otay Mesa knocking on doors, and even trucks that have that pretty little decal on the hood, and have seen them in PA on I-80 many years ago
  7. austinmike
    98,446
    What was the result?
  8. crazybread
    312
    58
    Jul 30, 2015
    thank for all the replies it seems like not having a APU will not be a problem.
  9. MM3Deg
    MM3Deg Medium Load Member
    354
    159
    Sep 23, 2007
    Fort Worth, TX
    What companies actually have APU trucks??
    I know it's only been a few months so far... But I have noticed maybe 4?? Those were independent OO.
    98% trucks idling at truck stop.. I just assumed the 2% were in the shower or restaurant...
    If companies are advertising it.... Expect to roll out MUCH SLOWER THAN THE CAMERA INSTALLS.
    I bet a rookie would get his 2-3 years experience before his APU.
    crazybread Thanks this.
  10. crazybread
    312
    58
    Jul 30, 2015
    Well i hear Prime Inc comes with APU on the trucks
