Not sure if this is a good idea after all. Inverter to block heater
Discussion in 'Experienced Truckers' Advice' started by Infosaur, Feb 12, 2016.
  1. Infosaur
    Infosaur Road Train Member
    In preparation for the cold snap this weekend my boss wants all the trucks plugged in if possible. But since my truck sits out in a field, I thought it'd be brilliant to turn on the inverter and plug the block heater into that, with the tri-pac monitoring battery life. (Supposedly the apu and the main engine share coolant but I'm not so sure. I think the guy who installed them in our fleet didn't do that for some reason, it's come up in the past)
    Now my spidey senses are tingling, I'm overlooking something. Does the block heater use some inordinate amount of wattage? Will the inverter over heat from prolonged use?
    I'm going to check it in an hour to make sure everything is kosher, but I want to leave it for the weekend.
    Am I overlooking something?
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    I suspect your gut sense is right. Don't use your inverter for block heat. Steal ac power from somewhere else if you have to.
    Infosaur Thanks this.
  4. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Probably around a 1000 watts. What's your inverter rated for on continuous, not peak power?
    It wouldn't use more than 15 amps on a regular 120 volt circuit which would be over 1500 watts.
  5. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    Don't some APU systems power block heaters rather than plumbing the coolant?
    Seems a better solution would be an espar coolant heater that you can program to fire up on its own.
  6. AModelCat
    158,485
    I suppose its doable. Don't know how long your batteries would last though. Might be better off bringing a little gas generator out for the night.
    PackRatTDI Thanks this.
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    if the m
    main engine and apu share coolant then why plug in the block heater? just run the apu it will circulate the coolant and keep it warm through the whole system.if not then plug it in and run apu to keep battries charged.
  8. Infosaur
    Apu and main engine are NOT connected coolant systems.
    They are SUPPOSED to be, but for some reason they aren't on our fleet.
  9. Infosaur
    Yeah it's a big inverter but I don't know the rating on it. I'm out now but I'm going to check it tonight.
  10. Infosaur
    Well, it sort of worked.
    The block heater stayed warm but the APU ran all weekend. But there wasn't enough juice for the rest of the truck. A voltage saving circuit turned off my interior lights (that's how I knew there was a problem) so unplugged the block heater, turned off the inverter, left the APU running and went back inside for breakfast & a latrine break.
    Started just fine when I came back.
  11. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    I think a lot of fleets opt to not plumb them together from a maintenance standpoint. If the APU springs a leak, it doesn't drain the main engine.
