1. steve092
    steve092 Light Load Member
    298
    79
    Dec 7, 2015
    Hey guys I had an issue with my 2013 Pete 386 about a week ago. It was driving perfect. I parked it for about 4 days and came back to start it up than a check engine light came up. I had the the ecm scanned and it showed Inlet Nox Sensor. So here I am spent $1200 to replace the sensor and lght is still on. I was told to drive it for about 30 to 50km and now I am at 60km and light is still on.
    Please help what should I do?
    Truck engine is a Paccar Mx13 with 18spd Eaton Fuller
  3. skysail
    skysail Bobtail Member
    6
    Not sure about Petes or Paccar at all, but there may be two nox sensors that should be replaced, clear the codes, then do a regen.
  4. Diesel Dave
    9,520
    31,498
    Jan 20, 2010
    Hesperia, Ca.
    The Paccars that one of the brokers I use have, all have had issues with all the emissions stuff and been in the shop several times for same issues. All of them are for sale
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Is it the MIL or check engine lamp? Who ever fixed it should have reset the MIL, but if they didn't, it'll stay on for 3-4 days or up to 500 miles.
    Oxbow Thanks this.
  6. steve092
    298
    79
    Dec 7, 2015
    Check engine light came up, all it said under fault codes was see operators manual and nothing else. Operators manual stated that the truck could be driven safely but issue must still be taken care of. He tried resetting the light once sensor was replaced and it did not go.
    Truck is already derated, my turbo will not spool properly because of this.
  7. steve092
    298
    79
    Dec 7, 2015
    Peterbilt is saying if issue is still there it may not be the nox sensor
    Jazz1 Thanks this.
  8. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    So it's not fixed, that should have been obvious to the mechanic when he couldn't reset the fault, active faults will not reset.
    Do you know the exact fault code that they got from it?
    Oxbow Thanks this.
  9. MACK E-6
    49,916
    237,093
    $1200 for a @#$& SENSOR?! :biggrin_1square5:
    That is bloody ridiculous.
  10. steve092
    298
    79
    Dec 7, 2015
    UPDATE GUYS:::::: A ##### "squirrel" got into my firewall and chewed up my engine harness and stashed its food inside!!!!!!!!!!!!!!!!Motherf**ker
    Jazz1, Heavyd and GrapeApe Thank this.
  11. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Be careful repairing it. If it's only a few wires and you've got a little room, you can do a good repair. Use good solder connections that are sealed, this is no place for cheap butt connectors (no place is a good place for cheap butt connectors actually). If there's a lot of damage and you have any questions about the quality of a repair, get a new harness.
    These are the only style butt connectors I use:
    Butt Connector Multilink
    Make sure that you crimp with the correct crimpers that will not pierce the insulation, then heat until the solder melts and they are sealed. A heat gun is best, open flame mini torches are not good for these unless they have the heat deflector attachment for heat shrink tubing.
    Is the 1st shop doing anything about the $1200 misdiagnosis? I tell my guys all the time, no matter how simple, go trough the entire diagnostic process. Even if 9 out of 10 times that fault code needs a sensor, that 10th one will bite you. You don't stay in business long if you screw every 10th customer, especially when it's a $500 sensor. It would have taken 10-15 min to follow the troubleshooting and ohm out the harness from the sensor to the ECM.
    spsauerland and Shaggy76 Thank this.
