I'm looking at a 2005 T2000 for personal use. The odometer reads 667xxx. Is it possible that this truck has 1 million 667xxx miles on it? Does the digital odometer record the seventh digit or does it start over at 999999.0? Thanks, Ron (new member)
odometer reading in 2005 t2000
Discussion in 'Kenworth Forum' started by chevyman486, May 29, 2013.
Its possible. But, highly unlikely. ..
You say unlikely but on the chance it could happen would the odometer read 1677000.0?
Just take it to the shop to print it off the ecm it is very common to have had a speedo go bad and a new one put in ecm and dash should match within 1% or so if it don't then something been changed or they are not truthfull
EZX1100 Thanks this. -
Well I figured out part of my question. I found a used kenworth (2005) that had 1,236,000 on it but after looking at the photos it only showed 236000 on the odometer. So I guess the 1 million digit
get does not appear on T2000 type trucks. Now I will have dealer run it on computer and see actual mileage. Thanks to all for you responses. Ron
