Of the mechanics. Oil pressure above 100 psi!!
Discussion in 'Ask An Owner Operator' started by Xenergiserx, Jun 7, 2021.
  1. Xenergiserx
    Xenergiserx Bobtail Member
    41
    18
    Feb 2, 2021
    Truck was running fine. I When to do my oil change I put Mobil oil. I ran 8 miles and the oil pressure when crazy to above 100 psi. What could be wrong .
    im on the side of the road
    cummin isx15
    519000
    Trucking Jobs in 30 seconds
  3. blairandgretchen
    9,403
    41,569
    Dec 9, 2011
    South west Missouri
    Pegged out!
    I would check the guage with an alternative scan device. Sender/guage fault elimination.
  4. Xenergiserx
    41
    18
    Feb 2, 2021
    I called the oil tech people they came to the rescue. The oil filte was defective. He replaced it and I was on my way.
  5. AModelCat
    101,242
    International truck?
    I'd be leery of the oil filter being the cause if it is. International's gauges go to the 6 o'clock position when there's a fault in the circuit. Might have been a glitch or you might have a wiring issue developing.
  6. Xenergiserx
    41
    18
    Feb 2, 2021
    Yeah international are not good on the electricals . But the truck has never given oil pressure problems and it happens 5 mins after the oil change. Tech said sometime they come defective from factory. And they have no way to check it. Truck ran fine after filter change
  7. blairandgretchen
    9,403
    41,569
    Dec 9, 2011
    South west Missouri
    Wow. Defective oil filter?
    God prefers Diesels Thanks this.
  8. SmallPackage
    2,469
    6,779
    Dec 20, 2019
    Marion Texas
    Don’t know how the oiling system works on the x15 but if it was an N series and pressure raises like that it could mean the regulator valve stuck open in oil cooler and is allowing full oil pump pressure out through the cooler and into the galleys.
  • Draft saved Draft deleted
